sizo0708
Hello everyone,
I have a task to create a simulation in ADS of a full wave voltage rectifier with a multiband/wideband matching.
In the input I used the P_nTone with 4 frequencies: 1.8GHz, 2.1GHz, 2.45GHz, 2.6GHz.
After that comes the matching network which is my issue here, I want to design it so that it will match the circuit to 2 frequencies which are 1.95GHz (center frequency between 1.8GHz and 2.1GHz) and 2.52GHz (center frequency between 2.45Hz and 2.6GHz).
Lastly, the full wave rectifier with a load ressistor come right after the MN.
How can I perform the matching? Can you provide me with methods and maybe even illustrations if you may?
The circuit along with the impedances in the desired frequencies below:
