But AFIK, you can run Modelsim multiple times and each would run on a different core. This way, you'll be able to run multiple simulations at the same time.No. Its only single threaded.
That will work - just make sure you have plenty of ram and a decent disk!
I want to accelerate Modelsim's work speed, do not simulate a few models at the same time.
There are faster and multi-core versions of ModelSim available. It's called Questa.No. Its only single threaded.
Does it have "student edition" like Modelsim?
Hello everyone.
Imagine i have multi-core CPU (2 or 4, nevermind). Can i use all cores to accelerate a simulation in Modelsim?
No. Modelsim remains as the student and entry level products.Questa has traditionally been the top level simulator that is the most expensive - but I'm sure Ive seen things recently that they are trying to rebrand all modelsim under the questa name - so maybe?
