Multi Band Cell phone WIFI GPS Portable jammer
a8242685
Newbie level 1
Newbie level 1
china
CDMA800-900:850-960MHz
GSM1800:1805-1880MHz
PHS1900:1920-1990MHz
3G:2110MHz-2170MHz
GPS:1520-1580MHz
WIFI:2400-2500MHz
Total output power: 360watt--500watt
Jamming range: Up to 300-500m, (It depends on the signal strength in the given area)
Power supply: AC110-240V, DC-24V
Dimension: 600×630×600 mm (L*W*H)
Characteristics:
1. Each module is controlled separately.
2. This jammer with pelican case can add band frequency as customer's requirements.
3. It can be used in car with battery and can be fixed in special occasion.
4. The output power, jamming range and band frequency can be adjusted.
5. Perfect Alarm System, Self Diagnostic Function
6. Automatically convert to Battery Power mode when AC Power Off (Min 2hours operating by Battery Power)
A "Smart active" cooling system enables unlimited continuous use.
The system has a fully protected circuit in case of disconnection of antennas.
The sturdy trolley type attach, case enables ease of mobility.
The jammer is designed for easy installation and use. Simply attach selected antennas and operate from the jammers outside batteries, or plug into either
AC mains or DC power source and start to operate.
All operational switches and check LEDs are externally installed.
Notice:
1. We have bomb jammer with pelican case and vehicle mounted jammer. And the band frequency and output power is optional.
2.The band frequency of bomb jammers is finally decided by our customer. The band frequency is optional. We highly appreciate you could tell us your detailed requirement, so we will design a plan to you.
3. If the bomb jammer is mounted in vehicle, please tell us the model and size of the car, so we will design the most suitable case. Thanks very much for kind cooperation.
if you need our jammers, pls feel free to email us as below
Fortune chou
Shenzhen Tangreat Technology Co., Ltd
Tel: 0086-755-33611881 Mobile: 0086-13670292315
Fax: 0086-755-82527821 Skype: tangreat0909
4F, R&D Building, Dacheng Industrial Park, Bantian, Shenzhen, China 518129
