memince
Newbie
Hi, I am making a rectenna system in ADS. I did the impedance mapping from the Smith Chart Tool. However, when I put MTEE between MLINEs, my S11 value changes. Why do you think it happens? I want the system to run at 2.14 GHz.
So I will not add MTEE on the schematic screen, but on the layout. Then will there be a change in S11 value?Have a look at the layout. MTEE adds some metal length, to make room for the T-junction. Also it includes the electrical effect of the connection including that metal.
thank you very muchOh .. no, no!
You misunderstand things. Schematic is there to represent your layout. Your schematic without MTEE is invalid because it models something you cannot build: an ideal junction with no parasitics.
To have a valid result, you must include MTEE, and layout shows what you get. You will need to tweak length of the lines connected to the MTEE.
I am so sorry. I don't know how to do what you said. I am new to this program.Oh .. no, no!
You must include MTEE in schematic, only that is a valid design that you can build. To compensate the change caused by the MTEE element, adjust length of lines connected to MTEE.I don't know how to do
