Dar89
Junior Member level 1
Hello,
I'm designing a simple circuit using Multi Supply Voltage. I'm using synopsys Dc Compiler for synthesys, therefore I must use UPF.
For the physical implementation I will use Cadence encounter which doesn't support UPF, but requires a CPF.
Since my design is simple (I have only one power mode) the translation from UPF to CPF is simple, but is it safely using UPF in synthesis and CPF in P&R ? Is this approach standard or coud rise some issues?
