[General] MSP430 F5529 LaunchPad Evaluation on ENERGIA IDE
adoniaamir
Newbie level 3
Newbie level 3
1. Where to find out that where is the words specified for pin configuration on the Launchpad board.
Such as RED_LED, GREEN_LED. Is there any header file explaining the denotions?
2. Immediately, when the program is downloaded into the Launch Pad. The LEDS are not working, since I press the reset or bsl button which makes the leds blinks?
3. The LEDS are working in following manner: Can you tell why is it like that?
1. RED - 1 GREEN - 1
2. RED - 1 GREEN -0
3. RED - 0 GREEN -0
4. RED - 0 GREEN - 1
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
//#define LED RED_LED
void setup()
// put your setup code here, to run once:
pinMode(GREEN_LED, OUTPUT);
pinMode(RED_LED, OUTPUT);
void loop()
led1();
led2();
void led1()
digitalWrite(RED_LED,HIGH);
delay(1000);
digitalWrite(GREEN_LED,LOW);
delay(1000);
void led2()
digitalWrite(RED_LED,LOW);
delay(1000);
digitalWrite(GREEN_LED,HIGH);
delay(1000);
Hello!
I suppose you are using what they call MSP430Ware or something like that. I think if you really want
to understand MSP430, the best thing is to download the hardware files from the following page:
https://www.ti.com/tool/msp-exp430f5529lp
And then write your own code based on TI examples.
- Don't use the launchpad examples (MSP-EXP430F5529LP Software Examples, slac623e.zip). These
examples are based on a hardware abstraction layer. Before that, you should first understand what happens
under the abstraction layer.
- My advice: use the F55xx specific examples (without abstraction layer) that can be downloaded from TI.
The file name is SLAC300n.zip, n being the version code. Today, it's slac300h.zip.
I had a look at the hardware file. The user leds (look at sheet 2 of the schematics) are on port 4.7
and on port P1.0
If you want to blink the LEDs, you may try this one using code composer studio:
NB: I don't know which LED is green or red, so I will name them LED1 (for port 1) and LED4 (for port 4).
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
#include "MSP430F5529.h"
#define    LED1    0x01
#define    LED4    0x80
void main(void) {
    WDTCTL = WDTPW + WDTHOLD; // Stop watchdog
    P4DIR |= LED4;   // LED4 bit in output
    P4OUT = &= ~LED4; // LED4 bit at 0 -> LED4 off
    P1DIR |= LED1;  // LED1 bit in output
    P1OUT $= ~LED1;  // LED1 bit at 0 -> LED1 off
    // Set the debugger breakpoint at next line
    P1OUT |= LED1; // LED1 on
    P1OUT &= ~LED1; // LED1 off
    P4OUT |= LED4; // LED4 on
    P4OUT &= ~LED4; // LED4 off
That's about it!
Dora.
PS: the above code has been written in EDABoard editor. I wouldn't trust my memory that much,
so there might be a few errors, but the principle is here.
