Not clear what you are asking for. A BASIC interpreter running on MS51DA9AE, a PC 8051 cross compiler?
It's the same instructions set and mostly identical SFR addresses. You probably need to edit some register definitions. There may be restrictions due to the concept of Mikroelektronika compilers to hide library code from the user. It's however worth a try.I doubt it.
It's a different chip manufacturer.
