ashad
Full Member level 6
- Joined
- Mar 28, 2006
- Messages
- 393
- Helped
- 40
- Reputation
- 80
- Reaction score
- 28
- Trophy points
- 1,308
- Location
- Trento, Italy
- Activity points
- 3,296
Dear all,
I wanted to ask one question regarding designing of MPPT. what I understand that wiring diagram of Solar Panel Power System
| Solar panel | ------------> | MPPT | ----------> | Inverter |
| battery |
I wanted to ask that if MPPT is connected to the Solar Panel and on the basis of output current it will track the MAximum power from the Solar Panel. it is one function of the MPPT to track the output power from solar panel and tune it to maximum point.
In the same time it is managed the battery charging also. if we use lead acid battery then it can be charge at Fixed voltage. so we can charge the battery with MPPT.
My Question is, if we wanted to connect the Inverter to the load so how MPPT manage the charging current and load current at the same time. Like if we have 200watt panel and 60watt load, then rest power i wanted to store in the battery.
so my question is how we manage this in term of Circuit point of view. Yes we can manage with Multiple controller but in circuit point of view how we charge the battery and drive the load at the same time circuit point of view
how controller manage it ?
Hope u understand my question
Thanks
Ashad Mustufa
| battery |
Thanks
Ashad Mustufa
