MPLB v6.1 and HITECH PICC
tjalps
Full Member level 5
Full Member level 5
SLOVENIA
htc picc how to compile
Hello!
Can you help me with some problem about integration of uper mentioned products. I simply don't get error message printed in debug vindow inside MPLAB.
Any idea?
Regards!
troubles
hi .. try to install to default paths ...
h***c does nopt like long path names :0(
regard
cancel
Hi !
A problem with Mplab6.1 has been corrected in last version
of FREE & LEGAL Hitech "picclite". (12/4/2002)
(Error Messages didn't appear in debug window)
I've made instalation to normal paths and replace this two files and still nothing.
Regards!
It looks that I have bigger problem. Ia ahev tried same with MPLAB v5.70 and I have same problem. I yust get message in debug window:
Building FRWATCH.HEX...
Compiling FRWATCH.C:
Command line: "C:\HT-PIC\BIN\PICC.EXE -FAKELOCAL -GMicrochip -Zg9 -E -X -12F675 -IC:\HT-PIC\SAMPLES;C:\HT-PIC\INCLUDE C:\PROGRA~1\MPLAB\PROJEKTI\FRWATCH\FRWATCH.C"
HI-TECH PICC COMPILER (Microchip PIC) V8.01 PL3
Copyright (C) 1984-2002 HI-TECH SOFTWARE
MPLAB is unable to find output file "FRWATCH.HEX". This may be due to a compile, assemble, or link process failure.
Build failed.
Please any help is welcome.
Regards!
1) Have you a file with "cce" extension in your working
directory ? Read it and you'll find infos on the first error
that cause stop compiling.
Here is the content of this file if I remove a semi-colon
in line 127 of a "12864.c" source file :
"Error[000] 12864.C 127 : expression syntax"
2) Did you try to compile your code with Hiitech IDE ?
Maybe your problem is in your source and not (only)
in Mplab integration....
I have same trouble. I just try my picc compiler+linker with sample code supply.
In mplab I select the hitech tool suite for the project.
Unfortunatly, when I build there is a failure at link and no more help in the error window !
I can't find any ".cce" file for more error details.
I have installed hitech tools under an other directory than the default one, I will try to reinstall under default one... and see...
Any help would be appraciate.
beuch
For problems of mplab-picc integration go www.htsoft.com under support and faq.
You can find info.
I have try everthing.
Please, help!
Regards!
mplab
goto window.. Check whether result window is present. Try updating the mplab or reinstall..
Regards
PRS
Hello!
I have find the source of problem. When I try to compile file in dos compiler widow and I'm configuring that, at the end I'm trying to configure the format of hex code I can't select the type of code( Bytcra, Intel...).
Any help is wellcome?
Regards!
try to look htpic's web site. There a fix for mplab that can resolve your problem
seems new version
Hello!
I think that this version if full of bugs and some stupid limitations.
I don't like it!
Regards!
I use the V6 every day and I think it's far better than the V5.
The editor is a real project environment.
There is context sensitive menus and powerful breakpoints.
But it's true there are some bugs...
But the hex file generated is OK.
beuch.
HTC PIC
I use hi-tech C compiler 8.00pl4 with MPlab 6.1 and work fine. I probe the demo of new version of HiTech and have some problems. I think that Microchip and HiTech must refine the integrations of both products and then launch new versions. Regards.
