Code ASM - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 ;********************************************************************** ; This file is a basic code template for object module code * ; generation on the PIC16F72. This file contains the * ; basic code building blocks to build upon. * ; * ; Refer to the MPASM User's Guide for additional information on * ; features of the assembler and linker (Document DS33014). * ; * ; Refer to the respective PIC data sheet for additional * ; information on the instruction set. * ; * ;********************************************************************** ; * ; Filename: xxx.asm * ; Date: * ; File Version: * ; * ; Author: * ; Company: * ; * ; * ;********************************************************************** ; * ; Files required: P16F72.INC * ; * ; * ;********************************************************************** ; * ; Notes: * ; * ; * ; * ; * ;********************************************************************** list p=16f72 ; list directive to define processor #include <p16f72.inc> ; processor specific variable definitions __CONFIG _CP_OFF & _WDTEN_OFF & _BODEN_OFF & _PWRTEN_ON & _RC_OSC ; '__CONFIG' directive is used to embed configuration data within .asm file. ; The labels following the directive are located in the respective .inc file. ; See respective data sheet for additional information on configuration word. ;***** VARIABLE DEFINITIONS (examples) ; example of using Uninitialized Data Section INT_VAR UDATA 0x20 w_temp RES 1 ; variable used for context saving status_temp RES 1 ; variable used for context saving ; creating copies of interupt context saving variables in bank1 INT_VAR1 UDATA 0xA0 w_temp1 RES 1 ; variable used for context saving ; example of using Uninitialized Data Section TEMP_VAR UDATA 0x22 ; explicit address specified is not required temp_count RES 1 ; temporary variable (example) ; example of using Overlayed Uninitialized Data Section ; in this example both variables are assigned the same GPR location by linker G_DATA UDATA_OVR ; explicit address can be specified flag RES 2 ; temporary variable (shared locations - G_DATA) G_DATA UDATA_OVR count RES 2 ; temporary variable (shared locations - G_DATA) ;********************************************************************** RESET_VECTOR CODE 0x0000 ; processor reset vector goto start ; go to beginning of program INT_VECTOR CODE 0x0004 ; interrupt vector location INTERRUPT movwf w_temp ; save off current W register contents bcf STATUS,RP0 ; select bank0 movf STATUS,w ; move status register into W register movwf status_temp ; save off contents of STATUS register ; isr code can go here or be located as a call subroutine elsewhere bcf STATUS,RP0 ; select bank0 movf status_temp,w ; retrieve copy of STATUS register movwf STATUS ; restore pre-isr STATUS register contents swapf w_temp,f swapf w_temp,w ; restore pre-isr W register contents retfie ; return from interrupt MAIN_PROG CODE start nop ; code starts here (example) banksel count ; example clrf count ; example ; remaining code goes here goto $ END ; directive 'end of program'
My project build is failed so how I can get ASM file. I have tried zip it and all other options but in vain. made new folder for project but can not see asm file there.
Need some guideline to move ahead
;***** VARIABLE DEFINITIONS (examples) ABSOLUTE MODE
CBLOCK 0X020
w_temp ; variable used for context saving
status_temp ; variable used for context saving
TEMP_VAR
temp_count ; temporary variable (example)
count
ENDC
ORG 0x000 ; processor reset vector
ORG 0x004 ; interrupt vector location
swapf w_temp,f
start
loop goto loop
WP100,
Thanks,
Your code works fine with absolute mode. I have copied both code in notepad and looking for difference what I can understand from it.
This will help me to start with basic programs Like LED and Push button. I have old parallel port programmer PCB4.5C. I have build circuit to read PIC using ICSP port and reading writing HEX file is working good.
Still I will need to look in clock frequency and then I will build another board to test the circuit. I have 16Mhz crystal (3pin) or may be I will buy 4 MHz or so and move ahead.
I will build HEX file from MPLAB and then I can use it with PCB4.5C software.
Where I can find the information about Relocatable and absolute code?
I will post my progress and for problem you guys are always helping.
;Tutorial 1.2 - Nigel Goodwin 2002 - Modified for Pic16f72
LIST p=16F72 ;tell assembler what chip we are using
include "P16F72.inc" ;include the defaults for the chip
__CONFIG _CP_OFF & _WDTEN_OFF & _BODEN_OFF & _PWRTEN_ON & _HS_OSC
; Configuration code using a 16mhz Crystal
cblock 0x20 ;start of general purpose registers / user variables
count1 ; delay routine work files
counta
countb
endc
org 0x0000 ;org sets the origin, 0x0000 for the 16F72
;this is where the program starts running
; set up the chips Ports
clrf PORTA ; clear all PORTS
clrf PORTB
banksel ADCON1 ; select Ram Bank 1
movlw 0x06 ; set all ports from Defualt Analogue to Digital
movwf ADCON1
clrf TRISA ; set all Ports to Digital Outputs
clrf TRISB
banksel 0 ;return to Ram bank 0
Loop
movlw 0xff
movwf PORTA ;set all bits on
movwf PORTB
call Delay ;this waits for a while!
movlw 0x00
movwf PORTA
movwf PORTB ;set all bits off
call Delay
goto Loop ;go back and do it again
; subroutine
Delay ; delay 500ms using 16mhz crystal
movlw 0x11
movwf count1
movlw 0x5D
movwf counta
movlw 0x05
movwf countb
Delay_0
decfsz count1, f
goto dlya
decfsz counta, f
dlya
goto dlyb
decfsz countb, f
dlyb
goto Delay_0
return
end ; end of program code
