MPC8349E-mITX development platform from MICETEK
candy227
mpc8349e mitx
Main Hardware for MPC8349E-mITX Platform:
1. CPU: Freescale MPC8349/8349E TBGA @ 266/533 (or 333/667) MHz
2. Memory system: 256-MByte (up to 1GByte) DDR1 DIMM SDRAM, 16-MByte Flash (two MacronixTM MX29LV640BT Flash Memory), Compact Flash connector
3. Interface:
1) LAN:TSEC 2, GMII interface: 5 x 10/100/1000 BaseT RJ-45, with VitesseTM VSC7385 SparX-G5TM 5+1 Port Gigabit Ethernet Integrated PHY Switch
2) WAN:TSEC1, GMII interface: 1 x 10/100/1000 BaseT with RJ-45 interface, using VitesseTM VSC8201 single port 10/100/1000 BaseT PHY
3) USB 2.0 high-speed (480Mbps, OTG and HUB):
USB1, ULPI interface: 4 x USB2.0 Type A receptable connector, with Genesys LogicTM GL850A 4-PORT USB 2.0 HUB Controller
USB2, ULPI interface: 1 x USB2.0 Type Mini-AB Receptable connector, with SMSCTM USB3300 Hi-Speed USB Host/Device/OTG PHY
4) Serial ATA controller:
5) Dual PCI :
1x 32-bit 3.3V PCI slot, connected to PCI-2
1x 32-bit 3.3V miniPCI slot, connected to PCI-2
Software of Platform:
1. BootLoader software: U-BOOT 1.1.3 version, supporting TSEC1/ TSEC2 10/100/1000M Ethernet port
2. linux kernel:
linux-2.6.13
PCI, USB2.0, GbEthernet, 10/100 Ethernet,ATA controller drivers
3. Tool chains:
gcc-4.0.3
glibc-2.3.2/uclibc0.9.29+binutils-2.6.1,
4. Root-file system(rootfs)
If you have any problem or inquiry, please feel free to contact me at international.sales@micetek.com or browse our webiste at www.micetek.com.
