MP3 file format and file structure
amraldo
Egypt
Hello,
Does anyone has explaination for the mp3 file format & file structure?
Regards,
Amraldo.
Re: mp3 file structure
i dont have any documents, but see these if they help.
h**p://mpgedit.org/mpgedit/mpeg_format/MP3Format.html
h**p://mpgedit.org/mpgedit/mpeg_format/mpeghdr.htm
Hello,
I am concerned in The mp3 file structure. How it is organized? How I can get timing information? & so on.
Regards,
Amraldo.
Try this
Look for more information at www.wotsit.org
An MP3 file is made up of multiple MP3 frames which consist of the MP3 header and the MP3 data. Frames are independent items: one can cut the frames from a file and an MP3 player would be able to play it. The MP3 data is the actual audio payload. The diagram shows that the MP3 header consists of a sync word which is used to identify the beginning of a valid frame. This is followed by a bit indicating that this is the MPEG standard and two bits that indicate that layer 3 is being used, hence MPEG-1 Audio Layer 3 or MP3. After this, the values will differ depending on the MP3 file. The range of values for each section of the header along with the specification of the header is defined by ISO/IEC 11172-3. Most MP3 files today contain ID3 metadata which precedes or follows the MP3 frames; this is also shown in the diagram.
