FEZAR
Newbie level 6
Hello everyone!
I have a problem with the RS485 connection. We use the FT 742D wind sensor in wind turbines, and we want to change the data speed rate for our purpose, also we need to understand how we can set the factory settings for the wind sensor.
As far as I understand, the sensor has the opportunity to change parameters via an RS485-2w connection. Here we have a connection problem, we don't have ping, however, we installed all the drivers and all the settings in the order provided by the hardware manufacturer.
Could you please give us some advice on how we can connect and apply a script that can change the baud rate speed and set a factory reset? You can also find information in the attachment.
FT702LT Wind Sensor Manual. Digital (RS485) - Flat Front Variant (1).pdf3 MB · Views: 201
