A complete OP equivalent circuit involves both, input current sources and input impedance (resistance || capacitance). You'll find it in many data sheet specifications.The input doesn't behave like a resistor at all. It is accurate enough to assume that input resistance is infinite. Input resistance is irrelevant in using op amp, the input bias current is used instead.
