Arushi Jain
Newbie
The following code results in the error under determined model and the simulation breaks off.
How should I remove the error. I have coded in Hamster Vhdl
library IEEE;
use IEEE.MATH_REAL.ALL;
LIBRARY DISCIPLINES;
USE DISCIPLINES.ELECTROMAGNETIC_SYSTEM.ALL;
entity equation is
port( quantity x1,x2,x3,x4,x5 : in real;
quantity fx1,fx2,fx3,fx4,fx5 : out real);
end equation;
architecture behav of equation is
begin
fx1 == x1**2.0 + 1.0;
break;
fx2 == x2**2.0 + 1.0;
break;
fx3 == x3**2.0 + 1.0;
break;
fx4 == x4**2.0 + 1.0;
break;
fx5 == x5**2.0 + 1.0;
end behav;
library IEEE;
entity TrapiRule is
--generic (n:real); -- number of intervals in which the function is to be divided.
port(
quantity a: inout real;
quantity b :in real;
quantity w2,w3,w4,w5: out real);
end TrapiRule;
architecture behav of TrapiRule is
quantity h : real;
--TYPE base IS ARRAY(0 to 5) of real;
--quantity x: base;
begin
h == (b-a)/5.0;
--procedural is
--begin
--for i in 1 to 5 loop
--x(i) := a + (i-1)*h;
--end loop;
w2 == a + h;
break;
w3 == a + 2.0*h;
break;
w4 == a + 3.0*h;
break;
w5 == a + 4.0*h;
end architecture behav;
library IEEE;
entity DefTra is
port(quantity y1,y2,y3,y4,y5: in real;
quantity result : out real);
end DefTra;
architecture behav of DefTra is
quantity res: real :=0.0;
quantity h : real;
begin
res == y1/2.0 + y2 +y3 + y4 + y5/2.0 ;
library IEEE;
entity testbench is
port(
quantity final:out real);
end testbench;
architecture behav of testbench is
quantity a,b,result: real;
quantity f2,f3,f4,f5:real;
quantity d1,d2,d3,d4,d5:real;
quantity m: real;
begin
BREAK
a=>1.0, b=>6.0;
tr1: ENTITY trapiRule (behav) PORT MAP (a=>a, b=>b, w2=>f2, w3=>f3, w4=>f4 , w5=>f5 );
eq1: ENTITY equation (behav) PORT MAP (x1=>a, x2=>f2 ,x3=>f3,x4=>f4, x5=>f5,fx1=> d1, fx2=>d2,fx3=>d3,fx4=>d4,fx5=>d5);
def1: ENTITY DefTra (behav) PORT MAP(y1=>d1,y2=>d2,y3=>d3,y4=>d4,y5=>d5, result=>result);
m== (b-a)/5.0;
final == result* m;
