[Moved] Verilog-A problem regarding square wave generation.
upasana sahu
Newbie
Newbie level 2
Hello,
I am trying to write verilog-A code to model a circuit .
I want to generate a square wave . Fot 0 to T(time) output should be low and for T to T1 time output should be high and it repeat .
Here is the code, however it doesn't seem to work.
Any help?
module Neuron16Jan(IN1,IN2,R1,G1);
input IN1,IN2;
output R1;
output G1;
electrical IN1,IN2,G1;
electrical gnd; //internal port
electrical R1;
parameter real slope_velocity_vs_currentdensity=0.11;
parameter real vlogic_low=225e-3;
parameter real vlogic_high=703e-3;
parameter real total_distance=5800e-9;
parameter real delt=209n;
real t;
real t1;
integer temp,next;
analog begin
V(gnd)<+0;
t=(total_distance)/((slope_velocity_vs_currentdensity)*(I(IN1,gnd)+I(IN2,gnd))*1e6);
t1=((total_distance)/((slope_velocity_vs_currentdensity)*(I(IN1,gnd)+I(IN2,gnd))*1e6))+209n;
@(initial_step) begin
temp=0;
end
@(timer(t)) begin
temp=0;
end
@(timer(t,t1)) begin
temp=1;
end
V(R1)<+ transition(temp ? vlogic_high:vlogic_low,0.01n,0.01n);
end
endmodule
This post is likely better suited for the Analog Integrated Circuit Design, Layout & Fabrication Questions. Analog ASIC Design sub-forum!
