YdaTron
Newbie
Hello Guys,
This is my first ever post in this forum ( If I'm in the wrong forum, please let me know)
I'm building a Test rig, switching couple of voltages both AC and DC and applying them to the DUT.
for the AC voltage application 100VaC/200VaC with an On state current of 1uA - 3uA tops. I'm evaluating different solutions that would be both functional and simple.
At first it was as simple as relay, then figured out that relays have a minimum load switching current in the order of milliamps. Then went for the solid state relay, based on Back to back MOSFETs, but the solution would be too complicated for such a simple application, and the used MOSFETs should have very low IDss compared to the actual load...
Couple of other ideas down the road, than it hit me why not use an actual OptoTriac, knowing that no significant load will ever be driven by it. and as long as it has a small Off current (10nA or less) and a voltage rating of 400V should be fine. I can also use one with Zero cross detection.
what do you guys think ? Any feedback would much appreciate.
