visva
Member level 3
how can set baud rate for communication in UART(with calculation). And what about range of baud rate. how to send data through TXD pin. Any example program in c for 89c52
#include <reg51.h>
sbit WAVE =P0^1;
void timer0() interrupt 1
WAVE=~WAVE; //toggle pin
void serial0() interrupt 4
if (TI==1)
TI=0; //clear interrupt
else
P0=SBUF; //put value on pins
RI=0; //clear interrupt
void main()
unsigned char x;
P1=0xFF; //make P1 an input
TMOD=0x22;
TH1=0xF6; //4800 baud rate
SCON=0x50;
TH0=0xA4; //5 kHz has T=200us
IE=0x92; //enable interrupts
TR1=1; //start timer 1
TR0=1; //start timer 0
while (1)
x=P1; //read value from pins
SBUF=x; //put value in buffer
P2=x; //write value to pins
