vamsee
Full Member level 1
![Full Member level 1](/styles/images/ranks/elevel1.gif)
I'm ready to move from plastic breadboard to the soldering type of prototype PCB. What i immediately notice is that I'm missing the very useful "connected strips" - those long strips that run at the bottom of the plastic breadboard that allow you to easily connect all your +5V and grounds.
So my question is how do I replicate this easily on a proto PCB? Do I start by drawing a long line with solder on the back of the PCB? But then I realise I will be blocking the holes to actually put the components in:roll: Do I solder the connecting line when I'm finished with soldering all components - on top of the component soldering? I've been searching for youtube videos on specifically this topic but all I could find are individual component soldering - never the "connection lines".
thanks!
thanks!
