wrq0049
Newbie level 1
![Newbie level 1](/styles/images/ranks/alevel1.gif)
Dear All:
1.0 I had simulated solar cell with TCAD but I got an error message as:
what is the mean of "Invalid card type specification"?
2. I used the sample for solar cell (example 3), I can used solarex03_15.spec file, but why I can not used this file in my program that is modify as example 3?
My program as follow:
Thanks for your help
"ATLAS> beam num=1 x.o=0.5 y.o=-0.5 angle=90 wavel.start=0.305 wavel.end=3.455 wavel.num=300
ATLAS> power.file=test.spec out.power=solarex03_15.log
** ERROR # 1 **
* Invalid card type specification * "
go atlas
mesh auto
x.m loc=0.0 s=0.25
x.m loc=1.0 s=0.25
# Here we specify an auxiliary quantum tunneling mesh used to
# help model the tunneling interface between the diodes.
qtx.m loc=0.0 s=0.25
qtx.m loc=1.0 s=0.25
qty.m l=0.66 s=0.002
qty.m l=0.675 s=0.001
qty.m l=0.69 s=0.002
qty.m l=4.34 s=0.002
qty.m l=4.40 s=0.001
qty.m l=4.54 s=0.002
# The tandem cell is formed by three p-n photodiodes stacked
# on top of one another. The three cells are separated by a GaAs tunnel junction.
#Top Cell
region material=InAlP bot thick=0.0300 accept=9e19 ny=10
region material=InGaP bot thick=0.1000 accept=5e17 ny=10
region material=InGaP bot thick=0.5000 donors=1e17 ny=10
region material=InAlGaP bot thick=0.0300 donors=1e18 ny=10
#Tunnel Junction 1 t=0.05
region material=GaAs bot thick=0.10 donors=2e20 ny=100
region material=GaAs bot thick=0.10 accept=1e20 ny=100
# Middle Cell t=2.84
region material=InGaAs bot thick=0.100 accept=5e18 ny=10
region material=InGaAs bot thick=3.450 donors=1.2e17 ny=10
region material=GaInP bot thick=0.100 donors=1e18 ny=10
#Tunnel Junction 2 t=0.05
region material=GaAs bot thick=0.10 donors=1e20 ny=10
region material=GaAs bot thick=0.10 accept=6e19 ny=10
#Bottom Cell t=2.84
region material=InGaAs bot thick=0.10 accept=1.5e18 ny=10
region material=Ge bot thick=0.05 accept=1.5e18 ny=10
region material=Ge bot thick=180.00 donors=5e18 ny=10
# Electrodes on top and bottom
electrode name=anode top
electrode name=cathode bottom
Tonyplot
# The complex index data will mostly use the Sopra database.
# The index data for InGaP is supplied in a file.
material mat=GaAs sopra=Gaas.nk
material mat=InAlGaP sopra=Againp.all
material mat=AlGaAs sopra=Algaas.all
material material=InGaP sopra=againp0.nk
material material=InAlP sopra=Againp10.nk
material material=InGaAs sopra=InGaAs.nk
material material=Ge sopra=ge.nk
# Here we define the affinity for InGaP and AlGaAs to
# set up the band alignment
material material=InGaP affinity=4.08
material material=AlGaAs affinity=3.54
# Enable physical models
models srh fermi conmob optr auger bgn
method itlimit=25 maxtraps=10
power.file=solarex03_15.spec out.power=solarex03_15.log
tonyplot input solar spectrum
tonyplot solarex03_15.log -set solarex03_15.set
# Here is an alternate simplified am0 solar spectrum
# Output optical intensity.
output band.temp opt.int
# save the initial structure
save outf=solarex03_15.str
solve vanode=0.01
solve vanode=0.5
solve name=anode vstep=0.1 vfinal=2.7
# Set NLBBT .
models srh fermi ni.fermi conmob optr auger bgn bbt.nonlocal bbt.nlderivs
solve b1=0.1
solve b1=1
log outf=solarex03_15.log
# Ramp the bias back.
solve name=anode vstep=-0.01 vfinal=2.2
solve name=anode vstep=-0.1 vfinal=0
# Extract important figures of merit.
extract init infile="solarex03_1.log"
extract name="Jsc" max(curve(v."anode", i."cathode"))
extract name="JscmAcm2" $Jsc*1e08*1e03
extract name="Voc" x.val from curve(v."anode", i."cathode") where y.val=0.0
extract name="Pm" max(curve(v."anode", (v."anode" * i."cathode")))
extract name="Vm" x.val from curve(v."anode", (v."anode"*i."cathode") ) \
where y.val=$"Pm"
extract name="Im" $"Pm"/$"Vm"
extract name="FF" ($"Pm"/($"Jsc"*$"Voc"))*100
extract name="Opt_int" max(beam."1")
extract name="Eff" (1e8*$Pm/$Opt_int)*100
# Plot the results
quit
