Brien Cheow
Newbie level 6
i have done most of the coding but the problem i am experiencing now is that after the first round of signal sensing, it does not refresh and restart the process. The problem could be from the for(;
loop because i tried leaving it out and it worked. but i need the for loop for my calculation.. please help...
Graphic LCD 64 by 128 pixels, Monochrome
SP5-GFX1
Connection to P2 of 8051 : Silicon Lab C8051F340
#1 GND
#2 +5V
#3 SI serial data -- P2.7
#4 SCL serial clock -- P2.6
#5 A0P 0 = select control, 1 = data port --- P2.5
#6 RESET low to reset LCD panel -- P2.4
#7 CS1 chip select, 0 = enable data transfer -- P2.3
#8 BL- Back light - GND
#9 BL+ Back light - +5V
Page memory for display : B0 to B7, eight pages, one page 128 bytes
each byte for 8 rows x 1 column, bit 0 at row 0, bit 1 at row 1 etc.
Version 1.0
//#include <reg51.h>
#include <c8051f340.h> // SFR declarations
// Global CONSTANTS
#define SYSCLK 12000000 // SYSCLK frequency in Hz
sfr16 ADC0 = 0xbd; // ADC0 result register
sfr16 TMR2RL = 0xca; // Timer2 reload value
sfr16 TMR2 = 0xcc; // Timer2 counter
sbit LCD_SI = P2^1;
sbit LCD_SCL = P2^2;
sbit LCD_A0P = P2^3;
sbit LCD_RESET = P2^4;
sbit LCD_CS1 = P2^5;
sbit LCD_SI = P2^7;
sbit LCD_SCL = P2^6;
sbit LCD_A0P = P2^5;
sbit LCD_CS1 = P2^3;
int i,j,k,m;
int s;
int p;
int *sp;
p = 0;
s = 0;
// 5 columns by 8 rows ASCII font, starting from SPACE, 0x20
code unsigned char font[] = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x5f,0x00,0x00, // !
0x00,0x03,0x00,0x03,0x00,0x14,0x7f,0x14,0x7f,0x14, // "#
0x24,0x2a,0x7f,0x2a,0x12,0x23,0x13,0x08,0x64,0x62, // $%
0x36,0x49,0x55,0x22,0x50,0x00,0x05,0x03,0x00,0x00, // &'
0x00,0x1c,0x22,0x41,0x00,0x00,0x41,0x22,0x1c,0x00, // ()
0x14,0x08,0x3e,0x08,0x14,0x08,0x08,0x3e,0x08,0x08, // *+
0x00,0x50,0x30,0x00,0x00,0x08,0x08,0x08,0x08,0x08, // ,-
0x00,0x60,0x60,0x00,0x00,0x20,0x10,0x08,0x04,0x02, // ./
0x3e,0x51,0x49,0x45,0x3e,0x00,0x42,0x7f,0x40,0x00, // 01
0x42,0x61,0x51,0x49,0x46,0x21,0x41,0x45,0x4b,0x31, // 23
0x18,0x14,0x12,0x7f,0x10,0x27,0x45,0x45,0x45,0x39, // 45
0x3c,0x4a,0x49,0x49,0x30,0x01,0x71,0x09,0x05,0x03, // 67
0x36,0x49,0x49,0x49,0x36,0x06,0x49,0x49,0x29,0x1e, // 89
0x00,0x36,0x36,0x00,0x00,0x00,0x56,0x36,0x00,0x00, // :;
0x08,0x14,0x22,0x41,0x00,0x14,0x14,0x14,0x14,0x14, // <=
0x00,0x41,0x22,0x14,0x08,0x02,0x01,0x51,0x09,0x06, // >?
0x32,0x49,0x79,0x41,0x3e,0x7e,0x11,0x11,0x11,0x7e, // @A
0x7f,0x49,0x49,0x49,0x36,0x3e,0x41,0x41,0x41,0x22, // BC
0x7f,0x41,0x41,0x22,0x1c,0x7f,0x49,0x49,0x49,0x41, // DE
0x7f,0x09,0x09,0x09,0x01,0x3e,0x41,0x49,0x49,0x7a, // FG
0x7f,0x08,0x08,0x08,0x7f,0x00,0x41,0x7f,0x41,0x00, // HI
0x20,0x40,0x41,0x3f,0x01,0x7f,0x08,0x14,0x22,0x41, // JK
0x7f,0x40,0x40,0x40,0x40,0x7f,0x02,0x0c,0x02,0x7f, // LM
0x7f,0x04,0x08,0x10,0x7f,0x3e,0x41,0x41,0x41,0x3e, // NO
0x7f,0x09,0x09,0x09,0x06,0x3e,0x41,0x51,0x21,0x5e, // PQ
0x7f,0x09,0x19,0x29,0x46,0x46,0x49,0x49,0x49,0x31, // RS
0x01,0x01,0x7f,0x01,0x01,0x3f,0x40,0x40,0x40,0x3f, // TU
0x1f,0x20,0x40,0x20,0x1f,0x3f,0x40,0x38,0x40,0x3f, // VW
0x63,0x14,0x08,0x14,0x63,0x07,0x08,0x70,0x08,0x07, // XY
0x61,0x51,0x49,0x45,0x43,0x00,0x7f,0x41,0x41,0x00, // Z[
0x02,0x04,0x08,0x10,0x20,0x00,0x41,0x41,0x7f,0x00, // \]
0x04,0x02,0x01,0x02,0x04,0x40,0x40,0x40,0x40,0x40, // ^_
0x00,0x01,0x02,0x04,0x00,0x20,0x54,0x54,0x54,0x78, // `a
0x7f,0x48,0x44,0x44,0x38,0x38,0x44,0x44,0x44,0x20, // bc
0x38,0x44,0x44,0x48,0x7f,0x38,0x54,0x54,0x54,0x18, // de
0x08,0x7e,0x09,0x01,0x02,0x0c,0x52,0x52,0x52,0x3e, // fg
0x7f,0x08,0x04,0x04,0x78,0x00,0x44,0x7d,0x40,0x00, // hi
0x20,0x40,0x44,0x3d,0x00,0x7f,0x10,0x28,0x44,0x00, // jk
0x00,0x41,0x7f,0x40,0x00,0x7c,0x04,0x18,0x04,0x78, // lm
0x7c,0x08,0x04,0x04,0x78,0x38,0x44,0x44,0x44,0x38, // no
0x7c,0x14,0x14,0x14,0x08,0x08,0x14,0x14,0x18,0x7c, // pq
0x7c,0x08,0x04,0x04,0x08,0x48,0x54,0x54,0x54,0x20, // rs
0x04,0x3f,0x44,0x40,0x20,0x3c,0x40,0x40,0x20,0x7c, // tu
0x1c,0x20,0x40,0x20,0x1c,0x3c,0x40,0x30,0x40,0x3c, // vw
0x44,0x28,0x10,0x28,0x44,0x0c,0x50,0x50,0x50,0x3c, // xy
0x44,0x64,0x54,0x4c,0x44,0x00,0x08,0x36,0x41,0x00, // z{
0x00,0x00,0x7f,0x00,0x00,0x00,0x41,0x36,0x08,0x00, // |}
0x10,0x08,0x08,0x10,0x08,0x00,0x00,0x02,0x05,0x02 }; // ^degree
// Function PROTOTYPES
void delay(int d); // delay by d ms
void delaya(void); // a short delay
void SYSCLK_Init (void); // set CPU clock
void PORT_Init (void); // init CPU ports
void LCD_reset(void); // reset LCD
void LCD_command(unsigned char); // Send command code to LCD
void LCD_data(unsigned char); // ASCII character to be displayed on LCD
void SPI_send(unsigned char); // shift 8 bit data to LCD SPI interface, high bit first
void write_char(unsigned char); // display an ASCII code at current position
void write_msg_xy(unsigned char, unsigned char, unsigned char*); // write strting at x col, y row
void set_xy(unsigned char x, unsigned char y); // set cursor position
void plot_xy(unsigned char x, unsigned char y);
//void timer0_interrupt(void) interrupt 1 using 1 //auto reload every 50us
void LCD_Clear_Display()
for(k=0; k<8; k++) // clear display
LCD_command(0xB0 + k); delay(20);
LCD_command(0x10); //high nibble of column address
LCD_command(0x00); // low 4 bits of column address
for(i=0; i<128; i++)
LCD_data(0x00);
void delay(int d) // delay for d ms
int i, j;
for(i=0; i<d; i++)
for(j=0; j<1179; j++);
void delaya() //a short delay
char j;
for(j=0; j<1; j++);
void timer0_interrupt_init()
TMOD = 0x01;
TR0 = 1;
TH0 = 0xD8;
TL0 = 0xEF;
EA = 1;
ET0 = 1;
while(TF0==0);
TF0 = 0;
void timer0 (void) interrupt 1
s++;
s=s;
sp = &s;
void main (void)
PCA0MD &= ~0x40; // WDTE = 0 (clear watchdog timer
// enable)
PORT_Init(); // Initialize Port I/O
SYSCLK_Init (); // Initialize Oscillator
// ADC init.
ADC0CN = 0x00; // ADC0 disabled, normal tracking,
// conversion triggered on TMR2 overflow
REF0CN = 0x03; //Internal voltage reference for ADC
AMX0P = 0x00; // 0x05=P2^6.. 0x13 ADC0 positive input = P1.1
AMX0N = 0x1F; // ADC0 negative input = GND
// i.e., single ended mode
ADC0CF = ((SYSCLK/3000000)-1)<<3; // set SAR clock to 3MHz
ADC0CF |= 0x00; // right-justify results
AD0EN = 1;
// SFRPAGE = TIMER01_PAGE; // Set SFR page
TH0 = -151; // -149; // Init Timer0 High register
TL0 = TH0; // Set the intial Timer0 value
ET0=1; // Timer0 interrupt enabled
TCON = 0x10; // Timer0 ON
TMOD = 0x02; // Timer0 in 8-bit reload mode
EA = 1; // allows interrupt
delay(200);
// initialize graphic LCD, set 8x8 fonts and graphic, OR mode for text and graphic
LCD_reset();
LCD_command(0xA2); // LCD bias, 1/9 bias
LCD_command(0xA0); // set normal display mode
LCD_command(0xC8); // set output mode
LCD_command(0x23); // set voltage regulator internal resistor
LCD_command(0x81); // electronic voltage double - two byte instruction
LCD_command(0x1D); // 6 bits, 0 to 0x2F, increase contrast
LCD_command(0x2B); // set power control circuit
LCD_command(0x40); // set start line = 0
LCD_command(0xAF); // setdisplay on
LCD_command(0x10); // lower 4 bits for high nibble of column address, 0 to 127
LCD_command(0x00); // lower 4 bits for low nibble of column address
LCD_command(0xB0); // set page address, B0 to B7 for 8 pages
LCD_Clear_Display(); //clear LCD screen
write_msg_xy(0, 0, "BVP(C)2015 NYP/BEMG 70BPM");
delay(200);
// enable timer interrupts
// ET0=1;
// TMOD=0x21;
// TR0=1;
// EA=1;
while(1)
for(k=0; k<127; k++)
m= 63 - (ADC0>>4); //take high 6 bits from the 10-bit adc
plot_xy(k, m);
plot_xy(k, m-1); // add two more dots for thicker lines
plot_xy(k, m+1);
delay(30);
AD0BUSY = 1; // start ADC conversion
if ((k & 0x1F) == 0 ) //draw straight lines
for(j=0; j<4; j++)
set_xy(k,4+j);
LCD_data(0xFF);
write_msg_xy(100, 55, sp);
//for(;;)
// { int n;
// n = (ADC0);
// if(n>p)
// p=n;
// else
// timer0_interrupt_init();
} // end while(1)
} // end main
// configure I/O ports
P1SKIP=0x20;
P1MDOUT = 0x0F;
P2MDOUT = 0x3F;
// P3MDOUT = 0xFF; // for ULN2803 drivers
// P4MDOUT = 0xFF;
// P0MDOUT = 0xFF; // for LTC1298, LCD interfaces
P2MDIN &= 0x0BF; // P2.6 as ADC0
P0MDOUT |= 0x10; // Enable UTX as push-pull output
XBR0 = 0x01; // Enable UART on P0.4(TX) and P0.5(RX)
XBR1 = 0x40; //0x40; Enable crossbar and weak pull-ups
// P2 = 0xFF;
// P3 = 0xFF;
// P4 = 0xFF;
P1MDOUT = 0x00; // enable P1 outputs
P2MDOUT = 0xFE;
P4MDOUT = 0xFF;
// P0MDOUT |= 0x10; // Enable UTX as push-pull output
// XBR0 = 0x01; // Enable UART on P0.4(TX) and P0.5(RX)
P2 = 0xFF;
P3 = 0xFF;
P4 = 0xFF;
// initializes the system clock to use the internal oscillator
OSCICN |= 0x03; // Configure internal oscillator
RSTSRC = 0x04; // Enable missing clock detector
// LCD routnies
// send one byte to SPI interface
void SPI_send(unsigned char dd)
unsigned char i;
LCD_CS1=0;
for(i=0; i<8; i++)
LCD_SCL=0; // set clock pulse low first
if( dd & 0x80 ) // set data bit
LCD_SI=1;
else
LCD_SI=0;
LCD_SCL=1; // clock high
dd = dd <<= 1; // shifted to next bit
LCD_CS1=1;
delaya();
void LCD_reset()
LCD_RESET = 0;
delay(10);
LCD_RESET = 1;
delay(10);
void LCD_command(unsigned char ch) { //send a command byte to LCD
LCD_A0P = 0;
SPI_send(ch);
delaya();
void LCD_data(unsigned char ch) { //send a data byte to LCD data port
LCD_A0P = 1;
SPI_send(ch);
// print an ASCII code on LCD at current text position
void write_char(unsigned char ch)
unsigned char * fontptr, k;
fontptr = font + (ch-0x20) * 5; // get the font pattern, 8 by 5
for(k=0; k<5; k++)
LCD_data( *fontptr++);
// display a message at column x, row y
void write_msg_xy(unsigned char x, unsigned char y, unsigned char *chptr)
char * ptr;
ptr = chptr;
set_xy(x, y);
while(*ptr)
write_char(*ptr++);
void plot_xy(unsigned char x, unsigned char y) // draw a dot at position x, y, x: 0 to 127, y:0 to 63
char ypage, dd=1;
ypage = y >>3;
set_xy(x, ypage);
ypage = y & 0x7; //low 3 bits for dot position
dd = dd << ypage;
LCD_data(dd);
// set LCD display position
LCD_command(0x10 | ( x>> 4) & 0x07 ); // lower 4 bits for high nibble of column address, 0 to 127
LCD_command(0x00 | x & 0x0F); // lower 4 bits for low nibble of column address
LCD_command(0xB0 | y & 0x07); // set page address, B0 to B7 for 8 pages
