soarhigh
Newbie level 2
I want to model the transmission of a wideband analog signal through a communication channel with a limited bandwidth in MATLAB. Lets say the signal has double the bandwidth of the channel.
My goal is to accurately recover the original signal with minimal distortion.
my method is to divide the SPECTRUM of the original signal into 2 parts by using a low pass filter and a high pass filter. Then the high passed signal will be shifted in freq into the bandwidth of the low pass filter.(heterodyning)
At the output, the 2 sub-band components will be combined to reconstruct the original signal. Meanwhile, the 2nd part will be shifted back to the high frequency band.
I want to use a phsically realisable filter, I have tried butterworth low-pass filter; but not good enough
say I have a signal: y=2*sin(2000*pi*T) + sin(4000*pi*T) and my communication channel has a bandwidth of 1kHz.
What type of filter will be most suitable for this task? and how can I achieve this in matlab.
Select the proper category for your question, what you are asking is irrelevant to "Service Manuals, Requests, Repair Tips" category
Message moved, [alexan_e]
