[Moved] Proteus 8 Header pin spacing
Ace Scottie
Newbie level 1
Newbie level 1
Hello im trying to create a PCB which has an Ardunio Pro Micro attatched.
Im having problem getting exact mesurements using Proteus as the 0.1mm snap point are too big, (need 15.24mm space can only get 15.3mm)
Secondly i need a CON15_1x15_2663 through hole spacer with the spacing being 2.54mm however i cant edit it and its set at 2mm by default.
is there a way i can edit the hole spacing on this part or is there a part i can use that allows editing.
(im english so please use mm as the conversions mess things up)
Ardunio dimentions and spacings - https://img.alibaba.com/img/pb/053/955/500/500955053_563.jpg
