That's the way it works.But when the PWM is '1' (=when LIN='1'), the voltage between VB and HO is always 0
To be exact: A MOSFET is OFF, when the voltage between gate and source is 0....the voltage between VB and HO is always 0. so the mosfet is off
Not in the posted schematics.I connect the driver pin according to the its datasheet.
I don´t see how this can be a boost converter.but the vout is 2 v (this is a boost converter!).
lease consider how to charge the bootstrap capacitor. Maybe you need an extra low side mosfet (VS=Drain, GND=sorce, LO = gate) just to charge the bootstrap capacitor.
