[SOLVED] [moved] problem in simulation OTFT verilogA model in cadence
electronicman26
Full Member level 2
Full Member level 2
hi
I want to simulate the verilogA model of OTFT transistor but see this error:
show us the verilog-a file, and how you put it in cadence?
What view do you set in "Switch View List" and "Stop View List" ?
Or use "config view" of Hierarchy Editor to choose veriloga or verilogams view.
Hi
I want to model a simple resistor with this verilogA code:
module simpleres(a, b);
inout a, b;
electrical a, b;
analog I(a,b) <+ V(a,b) / 1000;
endmodule
I try to do this modeling according to this: http://venividiwiki.ee.virginia.edu/mediawiki/index.php/ICDesignVerilogA
I do steps 1 and 2 but I have problem in step 3, after click a blank veriloga template popup but how I can transfer my code and how I can save it?? what should I do for save the code after type?
