[MOVED] PCB wizard problem in Altium
eamaster
Hi guys
i have a problem with DXP Import Wizard
sometimes when i import pcb like this in AltiumView attachment AVR ISP.zip
nothing is shows
but pcb actually exist
what should i do?
Check whether you have installed your importers.Unless it is installed it will show nothing.
SHABU
can you explain more
exactly where i should checked?
Check whether your file is completely imported to altium.It shows nothing.
I mistook that you can't find the file to import in the import wizard and asked you to check
SHABU
just drag and drop this file into altium and follow the steps.
Hi Anil,
The file which is converted by eamaster seems to have nothing in it.
I think thats his problem, not with the procedure for conversion.
SHABU
Hi shabu,
It is a .pcb file file (not sure what type of file), if you drag and drop it to altium one wizard will open then you have to follow the steps it will open the pcb file
No,I can't see PCB
I still have problem!!!
Hi eamaster,
This file designed in earlier version of altium(Protel)
If you open this file or do drag & drop to the altium you will be prompted by DXP import wizard window after that you have to follow few step,you will get your PCB file.
No need to go for file/ import wizard.
Find the attachment for converted file
  • AVR.rar
Thanks anilrock87,whan I drag and drop to altium
I think my altium have a problem!
but i dont know what is that!?:-(
Please check that you have installed importer/exporter plugins,
If not install it and then try to import it.
DXP / Plugins & Updates/Importer-exporter
thank you very much
you'r right
i solved it:p
Dear Eamaster,
Another option is just change file extantion that is *.Pcb to *.PcbDoc if file is created in protel.
