[Moved]: PCB Artist-layer change
optic_ali_optic
Newbie level 3
Newbie level 3
I use PCB artist software for a project, at first I used 4 layers, then I decided to use 6 layers, I was wondering is there any way I can replace the layers simply? for example just change it from setting? for example some of used routes are in layer 2, now I want to change all of them to be in layer 3.since I have too many routes I can't change them manually, I would be grateful if you can help me.
I don't know PCB Artist, does it have the ability to multi select routes?
Then you could select them all and change the layer.
If not then you are likely in for a longer task. :)
