[Moved] Opencv and BeagleBoard_xm
Firass
Newbie level 1
Newbie level 1
Hello All,
I cross compiled a C program for BB-XM and the generated executable file was executed successfully on the board. I used the Eclipse IDE and the toolchain generated by narcissus image for the cross compilation. But when the C program uses Open CV libraries the cross-compilation fail where no executable file is generated ( opencv functions are giving errors although i included the path to the header files ). I am using opencv 2.2 generated by narcissus image. Any help please.
Thank you
There was generated some error log for such compilation ?
yes andre there is error log. It is long but i think the problem is common. Between before compilation some times there is nor error red line under opencv functions.
The error log is as follows:
15:47:29 **** Build of configuration bb_debug for project cvbuild ****
make all
Building file: ../cvbuild.c
Invoking: GCC C Compiler
~/usr/local/angstrom/arm/bin/arm-angstrom-linux-gnueabi-gcc -I/root/Desktop/mywork/cv_build/build/install/include/opencv2 -I/root/Desktop/mywork/cv_build/build/install/include/opencv -I~/usr/local/angstrom/arm/arm-angstrom-linux-gnueabi/usr/include -O0 -g3 -Wall -c -fmessage-length=0 -MMD -MP -MF"cvbuild.d" -MT"cvbuild.d" -o "cvbuild.o" "../cvbuild.c"
In file included from ../cvbuild.c:10:
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui.hpp:46:33: error: opencv2/core/core.hpp: No such file or directory
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui.hpp:47:39: error: opencv2/highgui/highgui_c.h: No such file or directory
In file included from ../cvbuild.c:11:
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:45:33: error: opencv2/core/core_c.h: No such file or directory
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:77: warning: return type defaults to 'int'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h: In function 'CVAPI':
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:77: error: expected declaration specifiers before 'cvFontQt'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:79: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:81: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:82: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:84: error: expected ')' before '*' token
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:85: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:87: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:88: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:89: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:90: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:92: error: expected ')' before '*' token
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:93: warning: empty declaration
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:94: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:99: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:101: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:104: warning: empty declaration
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:126: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:129: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:130: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:133: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:136: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:137: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:141: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:143: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:146: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:149: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:152: error: expected ')' before '*' token
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:155: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:158: error: expected ')' before '*' token
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:160: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:165: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:166: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:168: warning: empty declaration
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:182: warning: empty declaration
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:192: error: expected ')' before '*' token
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:195: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:198: warning: empty declaration
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:218: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:219: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:221: warning: empty declaration
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:229: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:233: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:234: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:237: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:240: warning: empty declaration
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:247: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:250: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:257: error: storage class specified for parameter 'CvCapture'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:260: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:262: warning: empty declaration
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:295: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:299: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:305: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:309: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:312: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:314: warning: empty declaration
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:339: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:340: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:343: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:346: error: storage class specified for parameter 'CvVideoWriter'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:348: error: expected declaration specifiers before 'CV_INLINE'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:357: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:365: error: expected declaration specifiers before 'CVAPI'
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:368: error: expected declaration specifiers before 'CVAPI'
In file included from ../cvbuild.c:12:
/root/gnome-image-beagleboard/usr/include/opencv/highgui.h:48:39: error: opencv2/highgui/highgui.hpp: No such file or directory
In file included from ../cvbuild.c:13:
/root/gnome-image-beagleboard/usr/include/opencv/cv.h:65:39: error: opencv2/imgproc/imgproc_c.h: No such file or directory
/root/gnome-image-beagleboard/usr/include/opencv/cv.h:66:39: error: opencv2/imgproc/imgproc.hpp: No such file or directory
/root/gnome-image-beagleboard/usr/include/opencv/cv.h:67:38: error: opencv2/video/tracking.hpp: No such file or directory
/root/gnome-image-beagleboard/usr/include/opencv/cv.h:68:45: error: opencv2/features2d/features2d.hpp: No such file or directory
/root/gnome-image-beagleboard/usr/include/opencv/cv.h:69:35: error: opencv2/flann/flann.hpp: No such file or directory
/root/gnome-image-beagleboard/usr/include/opencv/cv.h:70:39: error: opencv2/calib3d/calib3d.hpp: No such file or directory
/root/gnome-image-beagleboard/usr/include/opencv/cv.h:71:43: error: opencv2/objdetect/objdetect.hpp: No such file or directory
/root/gnome-image-beagleboard/usr/include/opencv/cv.h:72:37: error: opencv2/legacy/compat.hpp: No such file or directory
In file included from /root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:34,
                 from ../cvbuild.c:14:
/root/usr/local/angstrom/arm/bin/../lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/include/stddef.h:214: error: storage class specified for parameter 'size_t'
In file included from /root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:36,
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:34: error: storage class specified for parameter '__u_char'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:35: error: storage class specified for parameter '__u_short'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:36: error: storage class specified for parameter '__u_int'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:37: error: storage class specified for parameter '__u_long'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:40: error: storage class specified for parameter '__int8_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:41: error: storage class specified for parameter '__uint8_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:42: error: storage class specified for parameter '__int16_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:43: error: storage class specified for parameter '__uint16_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:44: error: storage class specified for parameter '__int32_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:45: error: storage class specified for parameter '__uint32_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:50: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:51: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:59: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:60: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:137: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:138: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:139: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:140: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:141: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:142: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:143: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:144: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:145: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:146: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:147: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:147: error: expected declaration specifiers before '__fsid_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:148: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:149: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:150: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:151: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:152: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:153: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:154: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:156: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:157: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:158: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:161: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:164: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:167: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:172: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:173: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:176: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:177: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:180: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:181: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:183: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:187: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__loff_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:188: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:189: error: storage class specified for parameter '__caddr_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:192: error: expected declaration specifiers before '__extension__'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:195: error: expected declaration specifiers before '__extension__'
In file included from ../cvbuild.c:14:
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:49: error: storage class specified for parameter 'FILE'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:65: error: storage class specified for parameter '__FILE'
In file included from /root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:20,
                 from /root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:32,
                 from /root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:75,
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/wchar.h:90: error: storage class specified for parameter '__mbstate_t'
In file included from /root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:32,
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:24: error: expected specifier-qualifier-list before '__off_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:26: error: storage class specified for parameter '_G_fpos_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:29: error: expected specifier-qualifier-list before '__off64_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:31: error: storage class specified for parameter '_G_fpos64_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:53: error: storage class specified for parameter '_G_int16_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:54: error: storage class specified for parameter '_G_int32_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:55: error: storage class specified for parameter '_G_uint16_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:56: error: storage class specified for parameter '_G_uint32_t'
In file included from /root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:53,
/root/usr/local/angstrom/arm/bin/../lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/include/stdarg.h:43: error: storage class specified for parameter '__gnuc_va_list'
In file included from /root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:75,
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:180: error: storage class specified for parameter '_IO_lock_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:300: error: expected specifier-qualifier-list before '__off_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:341: error: storage class specified for parameter '_IO_FILE'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:346: error: storage class specified for parameter '_IO_2_1_stdin_'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:347: error: storage class specified for parameter '_IO_2_1_stdout_'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:348: error: storage class specified for parameter '_IO_2_1_stderr_'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:364: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__io_read_fn'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:372: error: expected '=', ',', ';', 'asm' or '__attribute__' before '__io_write_fn'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:381: error: expected declaration specifiers or '...' before '__off64_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:381: error: storage class specified for parameter '__io_seek_fn'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:384: error: storage class specified for parameter '__io_close_fn'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:416: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:417: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:418: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:458: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:459: error: expected declaration specifiers or '...' before '_IO_FILE'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:459: error: storage class specified for parameter '_IO_putc'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:460: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:461: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:463: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:469: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:470: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:471: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:488: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:490: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:492: error: expected '=', ',', ';', 'asm' or '__attribute__' before '_IO_padn'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:493: error: expected '=', ',', ';', 'asm' or '__attribute__' before '_IO_sgetn'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:495: error: expected '=', ',', ';', 'asm' or '__attribute__' before '_IO_seekoff'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:496: error: expected '=', ',', ';', 'asm' or '__attribute__' before '_IO_seekpos'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:498: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:91: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'fpos_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:145: error: storage class specified for parameter 'stdin'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:146: error: storage class specified for parameter 'stdout'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:147: error: storage class specified for parameter 'stderr'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:155: error: storage class specified for parameter 'remove'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:157: error: storage class specified for parameter 'rename'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:172: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:186: error: storage class specified for parameter 'tmpnam'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:192: error: storage class specified for parameter 'tmpnam_r'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:205: error: storage class specified for parameter 'tempnam'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:214: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:219: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:229: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:249: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:255: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:283: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:307: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:311: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:318: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:322: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:331: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:337: error: storage class specified for parameter 'printf'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:340: error: storage class specified for parameter 'sprintf'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:346: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:352: error: expected declaration specifiers or '...' before '__gnuc_va_list'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:352: error: storage class specified for parameter 'vprintf'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:355: error: expected declaration specifiers or '...' before '__gnuc_va_list'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:355: error: storage class specified for parameter 'vsprintf'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:361: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:363: error: storage class specified for parameter 'snprintf'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:363: error: format string argument not a string type
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:365: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:366: error: expected declaration specifiers or '...' before '__gnuc_va_list'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:367: error: storage class specified for parameter 'vsnprintf'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:367: error: format string argument not a string type
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:403: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:409: error: storage class specified for parameter 'scanf'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:412: error: storage class specified for parameter 'sscanf'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:509: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:510: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:516: error: storage class specified for parameter 'getchar'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:528: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:529: error: storage class specified for parameter 'getchar_unlocked'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:539: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:551: error: expected declaration specifiers or '...' before 'FILE'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:551: error: storage class specified for parameter 'fputc'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:552: error: expected declaration specifiers or '...' before 'FILE'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:552: error: storage class specified for parameter 'putc'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:558: error: storage class specified for parameter 'putchar'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:572: error: expected declaration specifiers or '...' before 'FILE'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:572: error: storage class specified for parameter 'fputc_unlocked'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:580: error: expected declaration specifiers or '...' before 'FILE'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:580: error: storage class specified for parameter 'putc_unlocked'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:581: error: storage class specified for parameter 'putchar_unlocked'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:588: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:591: error: expected declaration specifiers or '...' before 'FILE'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:591: error: storage class specified for parameter 'putw'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:600: error: expected declaration specifiers or '...' before 'FILE'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:601: error: storage class specified for parameter 'fgets'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:608: error: storage class specified for parameter 'gets'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:658: error: expected declaration specifiers or '...' before 'FILE'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:658: error: storage class specified for parameter 'fputs'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:664: error: storage class specified for parameter 'puts'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:671: error: expected declaration specifiers or '...' before 'FILE'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:671: error: storage class specified for parameter 'ungetc'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:678: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'fread'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:684: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'fwrite'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:706: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'fread_unlocked'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:708: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'fwrite_unlocked'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:718: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:723: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:728: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:742: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:747: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'ftello'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:767: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:772: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:795: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:797: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:799: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:804: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:805: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:806: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:815: error: storage class specified for parameter 'perror'
In file included from /root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:822,
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/sys_errlist.h:27: error: storage class specified for parameter 'sys_nerr'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/sys_errlist.h:28: error: storage class specified for parameter 'sys_errlist'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:827: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:832: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:842: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:848: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:854: error: storage class specified for parameter 'ctermid'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:882: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:886: error: expected ')' before '*' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:889: error: expected ')' before '*' token
In file included from ../cvbuild.c:15:
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:39: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:40: error: storage class specified for parameter 'memcpy'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:43: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:44: error: storage class specified for parameter 'memmove'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:52: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:53: error: storage class specified for parameter 'memccpy'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:59: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:59: error: storage class specified for parameter 'memset'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:62: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:63: error: storage class specified for parameter 'memcmp'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:66: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:67: error: storage class specified for parameter 'memchr'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:85: error: storage class specified for parameter 'strcpy'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:88: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:89: error: storage class specified for parameter 'strncpy'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:93: error: storage class specified for parameter 'strcat'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:96: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:96: error: storage class specified for parameter 'strncat'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:100: error: storage class specified for parameter 'strcmp'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:102: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:103: error: storage class specified for parameter 'strncmp'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:107: error: storage class specified for parameter 'strcoll'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:109: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'strxfrm'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:131: error: storage class specified for parameter 'strdup'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:168: error: storage class specified for parameter 'strchr'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:171: error: storage class specified for parameter 'strrchr'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:184: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'strcspn'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:188: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'strspn'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:192: error: storage class specified for parameter 'strpbrk'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:195: error: storage class specified for parameter 'strstr'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:200: error: storage class specified for parameter 'strtok'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:208: error: storage class specified for parameter '__strtok_r'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:212: error: storage class specified for parameter 'strtok_r'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:242: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'strlen'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:256: error: storage class specified for parameter 'strerror'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:270: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:270: error: storage class specified for parameter 'strerror_r'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:294: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:294: error: storage class specified for parameter '__bzero'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:298: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:299: error: storage class specified for parameter 'bcopy'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:302: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:302: error: storage class specified for parameter 'bzero'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:305: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:306: error: storage class specified for parameter 'bcmp'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:310: error: storage class specified for parameter 'index'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:314: error: storage class specified for parameter 'rindex'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:318: error: storage class specified for parameter 'ffs'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:332: error: storage class specified for parameter 'strcasecmp'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:335: error: expected declaration specifiers or '...' before 'size_t'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:336: error: storage class specified for parameter 'strncasecmp'
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:356: error: storage class specified for parameter 'strsep'
../cvbuild.c:18: error: expected '=', ',', ';', 'asm' or '__attribute__' before '{' token
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:354: error: declaration for parameter 'strsep' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:335: error: declaration for parameter 'strncasecmp' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:331: error: declaration for parameter 'strcasecmp' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:318: error: declaration for parameter 'ffs' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:313: error: declaration for parameter 'rindex' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:309: error: declaration for parameter 'index' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:305: error: declaration for parameter 'bcmp' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:302: error: declaration for parameter 'bzero' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:298: error: declaration for parameter 'bcopy' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:294: error: declaration for parameter '__bzero' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:270: error: declaration for parameter 'strerror_r' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:256: error: declaration for parameter 'strerror' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:210: error: declaration for parameter 'strtok_r' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:205: error: declaration for parameter '__strtok_r' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:199: error: declaration for parameter 'strtok' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:194: error: declaration for parameter 'strstr' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:191: error: declaration for parameter 'strpbrk' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:170: error: declaration for parameter 'strrchr' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:167: error: declaration for parameter 'strchr' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:130: error: declaration for parameter 'strdup' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:106: error: declaration for parameter 'strcoll' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:102: error: declaration for parameter 'strncmp' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:99: error: declaration for parameter 'strcmp' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:95: error: declaration for parameter 'strncat' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:92: error: declaration for parameter 'strcat' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:87: error: declaration for parameter 'strncpy' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:84: error: declaration for parameter 'strcpy' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:66: error: declaration for parameter 'memchr' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:62: error: declaration for parameter 'memcmp' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:59: error: declaration for parameter 'memset' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:51: error: declaration for parameter 'memccpy' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:43: error: declaration for parameter 'memmove' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/string.h:38: error: declaration for parameter 'memcpy' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:854: error: declaration for parameter 'ctermid' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/sys_errlist.h:28: error: declaration for parameter 'sys_errlist' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/sys_errlist.h:27: error: declaration for parameter 'sys_nerr' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:815: error: declaration for parameter 'perror' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:671: error: declaration for parameter 'ungetc' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:664: error: declaration for parameter 'puts' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:658: error: declaration for parameter 'fputs' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:608: error: declaration for parameter 'gets' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:600: error: declaration for parameter 'fgets' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:591: error: declaration for parameter 'putw' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:581: error: declaration for parameter 'putchar_unlocked' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:580: error: declaration for parameter 'putc_unlocked' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:572: error: declaration for parameter 'fputc_unlocked' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:558: error: declaration for parameter 'putchar' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:552: error: declaration for parameter 'putc' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:551: error: declaration for parameter 'fputc' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:529: error: declaration for parameter 'getchar_unlocked' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:516: error: declaration for parameter 'getchar' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:411: error: declaration for parameter 'sscanf' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:409: error: declaration for parameter 'scanf' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:365: error: declaration for parameter 'vsnprintf' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:361: error: declaration for parameter 'snprintf' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:354: error: declaration for parameter 'vsprintf' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:352: error: declaration for parameter 'vprintf' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:339: error: declaration for parameter 'sprintf' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:337: error: declaration for parameter 'printf' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:204: error: declaration for parameter 'tempnam' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:192: error: declaration for parameter 'tmpnam_r' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:186: error: declaration for parameter 'tmpnam' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:157: error: declaration for parameter 'rename' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:155: error: declaration for parameter 'remove' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:147: error: declaration for parameter 'stderr' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:146: error: declaration for parameter 'stdout' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:145: error: declaration for parameter 'stdin' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:459: error: declaration for parameter '_IO_putc' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:384: error: declaration for parameter '__io_close_fn' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:381: error: declaration for parameter '__io_seek_fn' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:348: error: parameter '_IO_2_1_stderr_' has incomplete type
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:348: error: declaration for parameter '_IO_2_1_stderr_' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:347: error: parameter '_IO_2_1_stdout_' has incomplete type
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:347: error: declaration for parameter '_IO_2_1_stdout_' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:346: error: parameter '_IO_2_1_stdin_' has incomplete type
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:346: error: declaration for parameter '_IO_2_1_stdin_' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:341: error: declaration for parameter '_IO_FILE' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:180: error: parameter '_IO_lock_t' has incomplete type
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/libio.h:180: error: declaration for parameter '_IO_lock_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/include/stdarg.h:43: error: declaration for parameter '__gnuc_va_list' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:56: error: declaration for parameter '_G_uint32_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:55: error: declaration for parameter '_G_uint16_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:54: error: declaration for parameter '_G_int32_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:53: error: declaration for parameter '_G_int16_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:31: error: declaration for parameter '_G_fpos64_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/_G_config.h:26: error: declaration for parameter '_G_fpos_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/wchar.h:90: error: declaration for parameter '__mbstate_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:65: error: declaration for parameter '__FILE' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/stdio.h:49: error: declaration for parameter 'FILE' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:189: error: declaration for parameter '__caddr_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:45: error: declaration for parameter '__uint32_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:44: error: declaration for parameter '__int32_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:43: error: declaration for parameter '__uint16_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:42: error: declaration for parameter '__int16_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:41: error: declaration for parameter '__uint8_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:40: error: declaration for parameter '__int8_t' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:37: error: declaration for parameter '__u_long' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:36: error: declaration for parameter '__u_int' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:35: error: declaration for parameter '__u_short' but no such parameter
/root/usr/local/angstrom/arm/bin/../arm-angstrom-linux-gnueabi/usr/include/bits/types.h:34: error: declaration for parameter '__u_char' but no such parameter
/root/usr/local/angstrom/arm/bin/../lib/gcc/arm-angstrom-linux-gnueabi/4.3.3/include/stddef.h:214: error: declaration for parameter 'size_t' but no such parameter
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:346: error: parameter 'CvVideoWriter' has incomplete type
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:346: error: declaration for parameter 'CvVideoWriter' but no such parameter
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:257: error: parameter 'CvCapture' has incomplete type
/root/gnome-image-beagleboard/usr/include/opencv2/highgui/highgui_c.h:257: error: declaration for parameter 'CvCapture' but no such parameter
../cvbuild.c:30: error: expected '{' at end of input
make: *** [cvbuild.o] Error 1
15:47:31 Build Finished (took 1s.372ms)
opencv2/core/core.hpp: No such file or directory
I´m not sure, but seems as that´s not an absolute path, but possibly relative to the folder where project is being compiled.
