T
treez
Is shielded coaxial cable for signal transmission, the be-all-and-end-all?
Also, does twisted pair offer more noise immunity than plain bifilar wire pair (not twisted)? (consider overall loop area the same in each case)
Also, when you get shielded coaxial cable, ie shield coating, then ground coating, then centre conductor....why do people put cable ferrites over the whole cable?...surely the cable ferrite should ideally not go over the shield?
