They are shorting the inverter and must not be there. Who has invented this circuit?Need help on the 2 Diode D1 and D2 in the Schematic
yes it is IN5407\IN5406The diode are IN5407
You mean, it's correct to connect diodes across a push-pull transformer?yes it is IN5407\IN5406
Incidentally, the driver circuit is VERY prone to leakage current, it effectively has four bipolar transistors in cascade, the slightest leakage in Q3/Q4 will be magnified many times by the overall gain.
