[Moved]: Need help in OrCad capture
panna25
Newbie level 1
Newbie level 1
Hello guys, I need to understand something. I have started using OrCad Pspice lite which I do not know if it is a corrupted file or not? This I wanted to use since many software does not have IC CD4047B, and after lot of struggle I found it in this software. Unfortunately for me, it ain't properly working for me. It has no Pspice option inside. So even I design my project, neither I can run it or simulate or make a PCB out of it.
I need help urgently cause i have a project to submit in a very short notice. And last of all I run the software as administrator, but it didn't help.
Try to use the following
OrCAD capture ICON> Right click > Run as administrator
PSPICE needs an extra license, if you don't have, it won't work.
