sretaw
Newbie level 1
Any possible reason that causing the inductor burnt? what are the debug step require to check any of the component is failing? Since visually it does not have any cosmetic problem ( solder bridging etc issue..)see attached circuit diagram and the failure component picture
View attachment Inductor.pdf
