tiwari.sachin
Full Member level 6
I am using a 7.4V battery (2200mAH),
AT some instance when the circuit draws more current, I see drop in this voltage. As my knowledge goes, it is because of internal battery resistance and the total resistance of the circuit where the voltage gets divided.
I tried connecting a DMM to measure current and a CRO for voltage.
Since I am using this to run a thermal printer, I see a lot of variations in current drawn and obviously its not constant and the current drawn depends on what is being printed.
These current changes are very fast and cannot be read by DMM or probably it changing way too fast for me to see any difference.
I did try with current resistor and using CRO to check voltage change. But again too fast and too many variations to know that maximum or average current.
I guess max current drawn is what i need to know at various battery conditions (100%, 75%, 50% so on)
How do I really check the maximum current my circuit is drawing.
