As shown in the bellowing figure, I plot the intrinsic gain of three nmos transistor with 180nm process.
The Vds of the three transistors are set to 0.75V, and then I sweep the Vgs voltage of all of them from 0 to 1.5V. (The Y-aix is the intrinsic gain, and the X-aix is the Vgs.) Their size are 5/0.5, 5/0.5, and 50/10, with the um unit.
From the figure, it seems that the intrinsic gains are almost the same for the nmos transistors which are biased at the same Vgs and Vds, regardless of their size.
Anyone can explain that why the gain is independent of the size? Thanks.
Re: intrinsic gain and (Vgs, Vds,W/L) relationsihp
Gain depends on output resistance, current and Gm:
Ro depends on your L, if you increase the length of transistor you will get higher gain.
So for a transistor with higher length you should get more gain.
---> However I see a minor problem here:
5/0.5 means W/L = 10 but 50/10 means W/L=5 so here, you have higher length but because of lower W/L ratio you obtain lower Gm so your gain does not change.
Thanks. Yes, you are right that one transistor with high gm but lower gain.
However, when I made the three transistors with the size(um): M1: W/L=5/0.5, M2: W/L=5/2, M3: W/L=5/10, and their gain V.S. Vgs plot is shown as the following figure, which shows that the gains are almost the same.
Your data implies that intrinsic gain is maximized at Vgs=0, which makes me suspect that something is wrong with your analysis or setup. How exactly are you defining/measuring intrinsic gain?
Hi mtwieg,
The intrinsic gain is defined by gm*ro or gm/gds.
Although Vgs=0, there are still some current going through the channel, with nA range. In this case, the transistors are not totally off, which is biased in the subthreshold region. Small current generates small gm, however, small current also leads to large ro(small gds), so it might be a maximum value intrinsic gain with Vgs=0. Thanks.
