[Moved] Identify MOSFET Transistor
kbtan
Member level 2
Member level 2
I am trying to use 4 mosfet tansistor to build a H-bridge to control the motor. The input voltage should be 12V and 1A. Can any one suggest which mosfet transistor is suitable for the circuit.
Thanks
Re: Identify MOSFET Transistor
Hello!
Why bothering using discrete components for 1A?
You can use chips (look at digikey with keyword = full bridge, then in PMIC and
fan controllers sub category).
You will find many chips with every possible voltage / current / number of circuits.
You will save the trouble of designing a decent motor driver. You will get a smart, small
solution and probably more reliable than anything you can do by yourself.
Dora.
Reactions: kbtan
    kbtan
excuse me, may i know whether using L293 IC as my H-bridge is better or i build it using mosfet transistor
Use L293. Its rating is 1 A. L293D is 600 mA. L293 is better because you board will look better.
Reactions: kbtan
    kbtan
may i know which is more power efficiency?
Use irf 3205
"I may recommended you to use H-bridge Mosfect transistor because it is better for switching.
Thanks!!!!!!"
