[Moved] I m stuck with this error for 2days..help
vinodhembedded
Junior Member level 2
i m using MICKRO C compiler 8.2
I m getting error like
';' expected but LCD_RS found
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
char txt1[] = "mikroElektronika";
char txt2[] = "EasyPIC5";
char txt3[] = "Lcd4bit";
char txt4[] = "example";
char i; // Loop variable
void Move_Delay() { // Function used for text moving
Delay_ms(500); // You can change the moving speed here
void main(){
TRISB = 0;
PORTB = 0xFF;
TRISB = 0xff;
ANSEL = 0; // Configure AN pins as digital I/O
ANSELH = 0;
Lcd_Init(); // Initialize LCD
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,6,txt3); // Write text in first row
Lcd_Out(2,6,txt4); // Write text in second row
Delay_ms(2000);
Lcd_Out(1,1,txt1); // Write text in first row
Lcd_Out(2,5,txt2); // Write text in second row
since the above program is a example program takn from MIckro c manual...
ths program itself not working for me..:-(
Please help
Re: I m stuck with this error for 2days..help
Sounds like you're missing a semicolon somewhere;
make sure the '}' is there with your main function's end.
hi
;is there
sorry i didnt type it ..
still not working..
can u anyone give me a simple program or syntax for using LCD in mikro c??
Actually if we use inbuilt functions lik Lcd_Init(), we have to mention Lcd module connections..isnt??
so if i try using sbit, its not working...
why soo??
help pros..:)
Thanks
did you enable the Lcd in the library manager. ? If not tick the Lcd box in the library manager tab in the RHS toolbar
hi geobabu..
thanks for the reply..
i think it ll help for sure.. how to go to library manager??
thanks
This is wrong.
Code C - [expand]
TRISB = 0;
PORTB = 0xFF;
TRISB = 0xff;
Why TRISB is set to 0xFF (input) when it is used for LCD as output. Remove that line. Void main() is missing the end brace }. Put a while(1); loop inside the void main()
