tuanha117@gmail.com
Newbie level 3
Dear friends
I am from Japan.
I am trying to use design compiler installed on server in my institute.
However, when I starting up design compiler by running command:
..../synopsys/Synthesis/current/bin/dc_shell-xg-t
on the server, a message said that
Fatal: Design Compiler is not enabled. (DCSH-1)
Since one other has able to start up design compiler (using the same command), I think this message relates to the environment of my user.
I am not really familiar with linux environment and design compiler environment.
Can any one tells me how can I setup the environment (and which files should I check and modified) so that I can run design compiler?
More information
I cannot find file ".synopsys_dc.setup" on my home directory, should I create it? or where should I expected it is? and contain?
Thank you all for kindness.
Tuan
I am from Japan.
More information
Tuan
