bianchi77
- Joined
- Jun 11, 2009
- Messages
- 1,313
- Helped
- 21
- Reputation
- 44
- Reaction score
- 20
- Trophy points
- 1,318
- Location
- California
- Activity points
- 9,442
I placed it already and still can not see the net....any idea ?through an "off-sheet" connector!!!
goto place--->off sheet connector
do you mean like this ? :i don't think the "out" connector of 89c51 is properly connected check its connection, it should show red cross before getting connected!!! moreover did you run your error check before moving on to pcb layout?? error will be shown if the pin is floating!!!
also put a net label on both the output wire of 89c51 and U4 to see in layout where is that particular net!!!
Thank you very much for the link, I'll see what I can fix and get back to you..yes like that.
compile the project it will give you error report at the end of compilation.
It shouldn't be a big issue anyhow...have a look :
