[Moved] how to find packages of a componetnt by its specifications?
BushraSultana
Chakwal, Pakistan, Pakistan
I am making footprints for components to make a printed circuit board. Actually i do have specs of component, by using that specs i have to find the packages for those components but i didn't find any way to identify the package of component by its specs niether i find any site from where i can get that packages. please help me in this regard if anyone eperienced this issue before. Thankyou
hi,
please post this spec i will try or else check in Digikey and findchip you may be get
go to Digikey or mouser there are parametric search option... with your specs you can narrow down to the components that are available on these vendors ... then you can have idea of different packages available .
i didn't find on digikey and anyother site, i am sending you specs for component please find it,
522mH 42206W Magnetics input common mode choke
144uH 77030A7 Kool-MU_125u Magnetics input differential mode choke
1.99uH 77030A7 KOOL-MU_125u Magnetics noise filter choke
4.1 mH EE-42515 P Magnetics Flyback type transformer
