David_
Advanced Member level 2
Hello.
Math has never been my strong side but I am trying to learn things I with certainty should have learned a long time ago, but I can't research the subject online since I don't know the English terminology for what am looking for.
I have these two equation:
fo = (FTW)(fs)/2³² with 0 ≦ FTW ≦ 2³¹
fo = fs*(1-(FTW/2³²)) with 2³¹ < FTW < 2³² - 1
This comes from a DDS chip datasheet and
fo = output frequency
fs = system clock frequency
FTW = Frequency Tuning Word.
I want to re-write the equations so that I can use it to find out what FTW I need to gain a specific fo, and I think it should be a simple matter of re-arranging the equations, that is simple if you do know how this sort of thing is done(which I don't).
Could someone show me how(to re-arrange the equations give the FTW needed for a specific fo) and tell me what category of mathematics I need to learn about, this is just one of many cases where I am hindered by my lack of mathematical knowledge and I experience that in many cases application notes give you all you need in the form of a starting or original equation but that is nothing if I can't re-work it.
I want to use this to write a C function that will be used as:
FTW = Hz_out(200000); // tuning word needed for a 200kHz output
I also fail to understand what the conditions for when which equation should be used actually says, this is regarding a DDS with a 32-bit frequency tuning word and I do get that 0 ≦ FTW ≦ 2³¹ means 0 is less than or equal to FTW while FTW is less than or equal to 2³¹(2 147 483 648)
and that 2³¹ < FTW < 2³² - 1 means when 2³¹(2 147 483 648) is less than FTW while FTW is less than 2³² - 1(4 294 967 295), but why would the equations be different for when the tuning word is between 0 & 2³¹ and when the tuning word is between 2³¹ & 2³² - 1?
This might be a little to DDS specific for this thread but if anyone reading this knows why please enlighten me.
I would appreciate any help very much.
Regards
Regards
