stranger12
Newbie level 5
Hi All,
I hope someone can help with below and I am posting in the right section.
My car has a bosch ecu(engine management unit) and once the car has been driven for 20-30 mins and then switched off, the engine will not start again .
My finding from numerous hours of investigation is the ecu gets hot and does not send signal to any of the other ecus needed to switch the car on such as transmission and fuel pump as confirmed by reading the errors. both repoted missing can signal from ecu .
Also when this happens , I can't access the ecu to check error etc .
as a result I get lots of error related to transmission and fuel pump fault which is a false alarm .
Now this happens only when the car is switched off otherwise the car can drive and run for hours and hours if not switched off.
so me thinking it is the ecu , i took it off and opened it . all seems good but it has on it what i refer to as thermal paste so think that is old and need replacing so that it transfers the heat .
Am I correct assuming this ? can i use cpu thermal paste on this circuit board?
can I check anything on the circuit board to verify if the board is gone ?
visually i am not seeing any cuts on the board or anything melting/corrosion.
is that ok ?
thanks
is that ok ?
thanks
