[Moved]: doubt on PMOSFET SOURSE terminal conections
arava prakash
Junior Member level 3
generally PMOSFET bulk(substrate) terminal is connected to more positive voltage in the circuit
but
can we connect PMOSFET bulk(substrate) terminal to ground
what happens if bulk terminal is connected to ground
HI
we wont do like this
this creates current flow from source to bulk, which is not needed
Thanks
Rajkumar S
It will be badly polarised. There is a PN junction between p-substrate and n-well. Also PN junctions beween n-well and p-MOSFET drain/source. These junctions have to be in reverse bias.
Why do you want to connect it to something else other than your high potential ?
Hi
In some design it may connect with source to avoid body effect, otherwise its better to connect with higher potential to avoid pn junction with forwardbias bettween source and bulk
Thanks
Rajkumar S
