[moved] Dedicated 4 channel PWM IC
mabauti
Member level 4
Member level 4
Hi everyone:
Recomend me a dedicated 4 channel PWM IC
There are multichannel buck PWMs (some w/ integrated
power switches) from LT/ADI and TI/National. But I am
not going to recommend a particular one since you say
not one thing about attributes beyond "4", and I have no
direct experience with any of them anyhow. Seems to me
that you would be best served by a distributor's component
selection utilities, on their web sites (what you can get,
trumps what you might like).
sorry dick_freebird.
I want to use it for controlling 4 dc motors 6V @ 1A
You should give specifications.
* pwm frequency (range)
* duty cycle range
* duty cycle resolution
Klaus
Hi Klauss, may be someone know about this
pwm frequency (range) : 200Hz to 2khz
duty cycle range : 5% to 95%
duty cycle resolution 8bits to 12bits
I don´t know any ready to buy IC.
A PLD could do this.
let´s say 10 bit resolution.
* 10 bit counter
* 4 registers with 10 bits each
This are at least 54 MCs.
Now it depends wht interface you have.
A 8 bit or 10 bit parallel interface may fit into a 72 MC device.
With I2C or SPI you need a larger one.
Klaus
