DaveKlebt
Newbie level 2
i need some assistance - i need to set up 5 MCP23017 to drive five banks of 16 channel relays. in testing the addressing to pins Ao, A1, and A2, i started with the relay banks.
I placed a ground on A0, A1 and A2 in the first I2C chip. The code uses the wiringpi Setup library. the addresses for the GPAO outputs is:
wiringpi.mcp23017Setup(101, 0x20) # set up the pins and i2c address
wiringpi.mcp23017Setup(117, 0x23) # set up the pins and i2c address
The I2C chip was set with A0 no ground, and A1 and A2 with grounds.
The second relay bank mirrors the action on the first.
When i alter the code to address the address on the range from 117 - 133) nothing happens.
any advice will most welcome.
