ncvhdl: 08.20-s024: (c) Copyright 1995-2010 Cadence Design Systems, Inc.
ncelab: 08.20-s024: (c) Copyright 1995-2010 Cadence Design Systems, Inc.
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:Alpha_reg_14) [File:LIA_FSM_gate.vhd, Line:215].
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:Alpha_reg_13) [File:LIA_FSM_gate.vhd, Line:216].
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:Alpha_reg_12) [File:LIA_FSM_gate.vhd, Line:217].
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:Alpha_reg_11) [File:LIA_FSM_gate.vhd, Line:218].
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:Alpha_reg_10) [File:LIA_FSM_gate.vhd, Line:219].
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:Alpha_reg_9) [File:LIA_FSM_gate.vhd, Line:220].
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:Alpha_reg_8) [File:LIA_FSM_gate.vhd, Line:221].
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:Alpha_b_reg_10) [File:LIA_FSM_gate.vh d, Line:511].
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:Alpha_b_reg_11) [File:LIA_FSM_gate.vh d, Line:512].
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:Alpha_b_reg_12) [File:LIA_FSM_gate.vh d, Line:513].
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:Alpha_b_reg_13) [File:LIA_FSM_gate.vh d, Line:514].
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:Alpha_b_reg_14) [File:LIA_FSM_gate.vh d, Line:515].
ncelab: *W,CUNOTB: component instance is not fully bound (:LIA_FSM_TB:uut:U148) [File:LIA_FSM_gate.vhd, Line:51 6].
-- Company:
-- Engineer:
-- Create Date: 09:00:02 06/16/2017
-- Design Name:
-- Module Name: LIA_FSM - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity LIA_FSM is
port(clk: in std_logic;
rst: in std_logic;
up: in std_logic;
dn: in std_logic;
PhaseMUX : inout std_logic_vector(9 downto 0);
PhaseMUX_b: inout std_logic_vector(9 downto 0);
Alpha: inout std_logic_vector(14 downto 0);
Alpha_b: inout std_logic_vector(14 downto 0)
end LIA_FSM;
architecture LIA_FSM_arch of LIA_FSM is
-- constant limit_low : std_logic_vector (1 downto 0):="01";
-- constant limit_high : std_logic_vector (7 downto 0):="10011111";
begin
process (clk)
variable CNT:std_logic_vector(7 downto 0):="00000000";
variable MSB_CNT: std_logic_vector (3 downto 0):="0000";
variable LSB_CNT: std_logic_vector (3 downto 0):= "0000";
begin
if rising_edge(clk) then
if (rst='0') then
if up = '1' then
CNT:= unsigned (CNT)+1;
end if;
if dn = '1' then
CNT:= unsigned (CNT)-1;
end if;
if (CNT< "00000001") then
CNT:= "10011111";
end if;
if (CNT> "10011111") then
CNT:= "00000001";
end if;
-- else
-- CNT:= "00000001";
end if;
if (rst='1') then
CNT:= "00000001";
end if;
LSB_CNT:= CNT (3 downto 0);
MSB_CNT:= CNT (7 downto 4);
case LSB_CNT is
when "0000" =>
Alpha <= "000000000000000";
Alpha_b <= not (Alpha);
when "0001" =>
Alpha <= "000000000000001";
when "0010" =>
Alpha <= "000000000000011";
when "0011" =>
Alpha <= "000000000000111";
when "0100" =>
Alpha <= "000000000001111";
when "0101" =>
Alpha <= "000000000011111";
when "0110" =>
Alpha <= "000000000111111";
when "0111" =>
Alpha <= "000000001111111";
when "1000" =>
Alpha <= "000000011111111";
when "1001" =>
Alpha <= "000000111111111";
when "1010" =>
Alpha <= "000001111111111";
when "1011" =>
Alpha <= "000011111111111";
when "1100" =>
Alpha <= "000111111111111";
when "1101" =>
Alpha <= "001111111111111";
when "1110" =>
Alpha <= "011111111111111";
when "1111" =>
Alpha <= "111111111111111";
when others =>
end case;
case MSB_CNT is
when "0000" =>
PhaseMUX <= "0000000001";
PhaseMUX_b <= "1111111110";
when "0001" =>
PhaseMUX <= "0000000010";
PhaseMUX_b <= "1111111101";
when "0010" =>
PhaseMUX <= "0000000100";
PhaseMUX_b <= "1111111011";
when "0011" =>
PhaseMUX <= "0000001000";
PhaseMUX_b <= "1111110111";
when "0100" =>
PhaseMUX <= "0000010000";
PhaseMUX_b <= "1111101111";
when "0101" =>
PhaseMUX <= "0000100000";
PhaseMUX_b <= "1111011111";
when "0110" =>
PhaseMUX <= "0001000000";
PhaseMUX_b <= "1110111111";
when "0111" =>
PhaseMUX <= "0010000000";
PhaseMUX_b <= "1101111111";
when "1000" =>
PhaseMUX <= "0100000000";
PhaseMUX_b <= "1011111111";
when "1001" =>
PhaseMUX <= "1000000000";
PhaseMUX_b <= "0111111111";
when others =>
end case;
end if;
end process;
end LIA_FSM_arch;
-- Company:
-- Engineer:
-- Create Date: 14:16:27 06/16/2017
-- Design Name:
-- Module Name: U:/Phd_Materials/Cadence_Simulation_Layouts/Simulation_ASIC/ISE/LIA_FSM/LIA_FSM_TB.vhd
-- Project Name: LIA_FSM
-- Target Device:
-- Tool versions:
-- Description:
-- VHDL Test Bench Created by ISE for module: LIA_FSM
-- Dependencies:
-- Revision:
-- Notes:
-- This testbench has been automatically generated using types std_logic and
-- std_logic_vector for the ports of the unit under test. Xilinx recommends
-- that these types always be used for the top-level I/O of a design in order
-- to guarantee that the testbench will bind correctly to the post-implementation
-- simulation model.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
--USE ieee.numeric_std.ALL;
ENTITY LIA_FSM_TB IS
END LIA_FSM_TB;
ARCHITECTURE LIA_FSM_TB_arch OF LIA_FSM_TB IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT LIA_FSM
PORT(
clk : IN std_logic;
rst : IN std_logic;
up : IN std_logic;
dn : IN std_logic;
PhaseMUX_b : inout std_logic_vector(9 downto 0);
Alpha : inout std_logic_vector(14 downto 0);
Alpha_b : inout std_logic_vector(14 downto 0)
END COMPONENT;
--Inputs
signal clk : std_logic := '0';
signal rst : std_logic := '0';
signal up : std_logic := '0';
signal dn : std_logic := '0';
--Outputs
signal PhaseMUX : std_logic_vector(9 downto 0);
signal PhaseMUX_b : std_logic_vector(9 downto 0);
signal Alpha : std_logic_vector(14 downto 0);
signal Alpha_b : std_logic_vector(14 downto 0);
-- Clock period definitions
constant clk_period : time := 20 us;
constant rst_period : time := 50 ms;
constant up_period : time := 20 ms;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: LIA_FSM PORT MAP (
clk => clk,
rst => rst,
up => up,
dn => dn,
PhaseMUX => PhaseMUX,
PhaseMUX_b => PhaseMUX_b,
Alpha => Alpha,
Alpha_b => Alpha_b
-- Clock process definitions
clk_process :process
begin
clk <= '0';
wait for clk_period/2;
clk <= '1';
end process;
rst_process :process
begin
rst <= '1';
wait for rst_period/(2*10);
rst <= '0';
wait for rst_period/2;
end process;
up_process :process
begin
up <= '1';
wait for up_period/2;
up <= '0';
end process;
dn_process :process
begin
dn <= '0';
dn <= '1';
end process;
-- Stimulus process
stim_proc: process
begin
-- hold reset state for 100 ns.
wait for 100 ns;
wait for clk_period*10;
-- insert stimulus here
wait;
end process;
END LIA_FSM_TB_arch;
I don't get it. Are you doing behavioral or gate-level simulation? If you can't get the behavioral to work, you are clearly instantiating things incorrectly.
I have already done the behavioral simulation and there is no problem. I am at the gate level step (the code is synthesized by Synopsis) and I get stuck in this step.
So do you understand now why posting the behavioral code is pointless? I am afraid you don't understand the difference between these two.
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 library IEEE,tpz973g,prim; use IEEE.std_logic_1164.all; use tpz973g.all; use prim.all; package CONV_PACK_LIA_FSM is -- define attributes attribute ENUM_ENCODING : STRING; end CONV_PACK_LIA_FSM; library IEEE,tpz973g,prim; use IEEE.std_logic_1164.all; use tpz973g.all; use prim.all; use work.CONV_PACK_LIA_FSM.all; entity LIA_FSM is port( clk, rst, up, dn : in std_logic; PhaseMUX, PhaseMUX_b : out std_logic_vector (9 downto 0); Alpha, Alpha_b : out std_logic_vector (14 downto 0)); end LIA_FSM; architecture SYN_LIA_FSM_arch of LIA_FSM is component CLKINVX20 port( A : in std_logic; Y : out std_logic); end component; component DFFTRXL port( D, RN, CK : in std_logic; Q, QN : out std_logic); end component; component DFFXL port( D, CK : in std_logic; Q, QN : out std_logic); end component; component INVX1 port( A : in std_logic; Y : out std_logic); end component; component NAND2X1 port( A, B : in std_logic; Y : out std_logic); end component; component OAI21XL port( A0, A1, B0 : in std_logic; Y : out std_logic); end component; component NAND4X1 port( A, B, C, D : in std_logic; Y : out std_logic); end component; component NOR3X1 port( A, B, C : in std_logic; Y : out std_logic); end component; component NAND3X1 port( A, B, C : in std_logic; Y : out std_logic); end component; component AOI21X1 port( A0, A1, B0 : in std_logic; Y : out std_logic); end component; component AOI22X1 port( A0, A1, B0, B1 : in std_logic; Y : out std_logic); end component; component OAI211X1 port( A0, A1, B0, C0 : in std_logic; Y : out std_logic); end component; component NOR2X1 port( A, B : in std_logic; Y : out std_logic); end component; component OAI31X1 port( A0, A1, A2, B0 : in std_logic; Y : out std_logic); end component; component NAND2BX1 port( AN, B : in std_logic; Y : out std_logic); end component; component XOR2X1 port( A, B : in std_logic; Y : out std_logic); end component; component OAI2BB1X1 port( A0N, A1N, B0 : in std_logic; Y : out std_logic); end component; component XNOR2X1 port( A, B : in std_logic; Y : out std_logic); end component; component AOI222X1 port( A0, A1, B0, B1, C0, C1 : in std_logic; Y : out std_logic); end component; component OR4X2 port( A, B, C, D : in std_logic; Y : out std_logic); end component; component OR2X2 port( A, B : in std_logic; Y : out std_logic); end component; component NOR2BX1 port( AN, B : in std_logic; Y : out std_logic); end component; component AND2X1 port( A, B : in std_logic; Y : out std_logic); end component; component ADDHXL port( A, B : in std_logic; CO, S : out std_logic); end component; component DFFX1 port( D, CK : in std_logic; Q, QN : out std_logic); end component; component DFFTRX1 port( D, RN, CK : in std_logic; Q, QN : out std_logic); end component; signal CNT_7_port, CNT_6_port, CNT_5_port, CNT_4_port, CNT_3_port, CNT_2_port, CNT_1_port, CNT_0_port, N42, N43, N44, N45, N46, N47, N48, N51, N52, N53, N54, N55, N56, N57, LSB_CNT_2_port, LSB_CNT_1_port, MSB_CNT_3_port, MSB_CNT_2_port, MSB_CNT_1_port, MSB_CNT_0_port, N180, N181, N182, N184, N186, N187, N188, N190, N192, N194, N266, N267, N268, N269, N270, N271, N272, N273, N274, N275, n19, n33, n34, n35, n36, n37, n38, n39, n40, n41, n420, n430, n440, n450, n460, n470, n49, n50, n510, n520, n530, n540, n550, n560, n570, n58, n59, n60, n61, n62, n63, n64, n65, n66, n67, n68, n69, n70, n71, n72, n73, n74, n75, n76, n77, n78, n79 , n80, n81, n82, add_75xcarry_2_port, add_75xcarry_3_port, add_75xcarry_4_port, add_75xcarry_5_port, add_75xcarry_6_port, add_75xcarry_7_port, n83, n315, n313, n325, n324, n322, n323, n321, n318, n314, n317, n316, n320, n312, n326, n319, n99, n101, n103, n105, n107, n109, n111, n113, n115, n117, n119, n121, n123, n125, n127, n129, n131, n133, n135, n137, n139, n141, n143, n145, n147, n149, n151, n153, n155, n157, n159, n161, n163, n165, n167, n169, n173, n174, n175, n176, n177, n178, n179, n1800, n1810, n1820, n183, n1840, n185, n1860, n1870, n1880, n189, n1900, n191, n1920, n193, n1940, n195, n196, n197, n198, n199, n200 , n201, n202, n203, n204, n205, n271_port, n272_port, n273_port, n274_port, n275_port, n276, n277, n278, n279, n280, n281, n282, n283, n284, n285, n286, n287, n288, n289, n290, n291, n292, n293, n294, n295, n296, n297, n298, n299, n300, n301, n302, n303, n304, n305, n306, n307, n308, n309, n310, n311, n_1000, n_1001, n_1002 : std_logic; begin CNT_reg_5 : DFFTRX1 port map( D => n83, RN => n174, CK => clk, Q => CNT_5_port, QN => n_1000); CNT_reg_6 : DFFTRX1 port map( D => n83, RN => n173, CK => clk, Q => CNT_6_port, QN => n_1001); LSB_CNT_reg_0 : DFFX1 port map( D => CNT_0_port, CK => clk, Q => n_1002, QN => n19); add_75xU1_1_4 : ADDHXL port map( A => CNT_4_port, B => add_75xcarry_4_port, CO => add_75xcarry_5_port, S => N45); add_75xU1_1_3 : ADDHXL port map( A => CNT_3_port, B => add_75xcarry_3_port, CO => add_75xcarry_4_port, S => N44); add_75xU1_1_2 : ADDHXL port map( A => CNT_2_port, B => add_75xcarry_2_port, CO => add_75xcarry_3_port, S => N43); add_75xU1_1_5 : ADDHXL port map( A => CNT_5_port, B => add_75xcarry_5_port, CO => add_75xcarry_6_port, S => N46); add_75xU1_1_1 : ADDHXL port map( A => CNT_1_port, B => CNT_0_port, CO => add_75xcarry_2_port, S => N42); add_75xU1_1_6 : ADDHXL port map( A => CNT_6_port, B => add_75xcarry_6_port, CO => add_75xcarry_7_port, S => N47); xcellx1887 : AND2X1 port map( A => n69, B => n193, Y => n169); LSB_CNT_reg_1 : DFFXL port map( D => CNT_1_port, CK => clk, Q => LSB_CNT_1_port, QN => n183); U82 : OR2X2 port map( A => n204, B => n203, Y => n83); U99 : CLKINVX20 port map( A => n99, Y => Alpha_b(14)); U101 : CLKINVX20 port map( A => n101, Y => PhaseMUX(1)); U103 : CLKINVX20 port map( A => n103, Y => Alpha_b(10)); U105 : CLKINVX20 port map( A => n105, Y => Alpha_b(12)); U107 : CLKINVX20 port map( A => n107, Y => Alpha_b(8)); U109 : CLKINVX20 port map( A => n109, Y => Alpha_b(9)); U111 : CLKINVX20 port map( A => n111, Y => Alpha_b(6)); U113 : CLKINVX20 port map( A => n113, Y => Alpha_b(7)); U115 : CLKINVX20 port map( A => n115, Y => Alpha_b(4)); U117 : CLKINVX20 port map( A => n117, Y => Alpha_b(5)); U119 : CLKINVX20 port map( A => n119, Y => Alpha_b(2)); U121 : CLKINVX20 port map( A => n121, Y => Alpha_b(3)); U123 : CLKINVX20 port map( A => n123, Y => Alpha_b(0)); U125 : CLKINVX20 port map( A => n125, Y => Alpha_b(1)); U127 : CLKINVX20 port map( A => n127, Y => Alpha_b(11)); U129 : CLKINVX20 port map( A => n129, Y => Alpha_b(13)); U131 : CLKINVX20 port map( A => n131, Y => PhaseMUX_b(4)); U133 : CLKINVX20 port map( A => n133, Y => PhaseMUX_b(6)); U135 : CLKINVX20 port map( A => n135, Y => PhaseMUX(6)); U137 : CLKINVX20 port map( A => n137, Y => PhaseMUX_b(2)); U139 : CLKINVX20 port map( A => n139, Y => PhaseMUX(2)); U141 : CLKINVX20 port map( A => n141, Y => PhaseMUX(4)); U143 : CLKINVX20 port map( A => n143, Y => PhaseMUX(5)); U145 : CLKINVX20 port map( A => n145, Y => PhaseMUX(7)); U147 : CLKINVX20 port map( A => n147, Y => PhaseMUX_b(7)); U149 : CLKINVX20 port map( A => n149, Y => PhaseMUX(3)); U151 : CLKINVX20 port map( A => n151, Y => PhaseMUX_b(3)); U153 : CLKINVX20 port map( A => n153, Y => PhaseMUX_b(5)); U155 : CLKINVX20 port map( A => n155, Y => PhaseMUX_b(9)); U157 : CLKINVX20 port map( A => n157, Y => PhaseMUX_b(1)); U159 : CLKINVX20 port map( A => n159, Y => PhaseMUX_b(0)); U161 : CLKINVX20 port map( A => n161, Y => PhaseMUX_b(8)); U163 : CLKINVX20 port map( A => n163, Y => PhaseMUX(9)); U165 : CLKINVX20 port map( A => n165, Y => PhaseMUX(8)); U167 : CLKINVX20 port map( A => n167, Y => PhaseMUX(0)); U168 : INVX1 port map( A => n71, Y => n193); U169 : NOR2BX1 port map( AN => n66, B => n175, Y => n530); U170 : NOR2X1 port map( A => n83, B => n65, Y => n520); U171 : NAND2X1 port map( A => n183, B => n76, Y => N181); U172 : INVX1 port map( A => n76, Y => n179); U173 : NAND2X1 port map( A => n1940, B => n195, Y => n71); U174 : NAND2X1 port map( A => n69, B => n193, Y => N267); U175 : INVX1 port map( A => n72, Y => n1810); U176 : INVX1 port map( A => n75, Y => n178); U177 : INVX1 port map( A => n74, Y => n177); U178 : INVX1 port map( A => N266, Y => n1840); U179 : INVX1 port map( A => N271, Y => n189); U180 : INVX1 port map( A => N273, Y => n1900); U181 : INVX1 port map( A => N269, Y => n1880); U182 : INVX1 port map( A => N274, Y => n191); U183 : INVX1 port map( A => N275, Y => n1920); U184 : INVX1 port map( A => N268, Y => n185); U185 : INVX1 port map( A => N270, Y => n1860); U186 : INVX1 port map( A => N272, Y => n1870); U187 : NOR2BX1 port map( AN => dn, B => n65, Y => n540); U188 : NOR2BX1 port map( AN => n66, B => up, Y => n510); U189 : OAI31X1 port map( A0 => n183, A1 => n1820, A2 => n19, B0 => n1800, Y => N186); U190 : NOR2X1 port map( A => LSB_CNT_2_port, B => N184, Y => n76); U191 : AOI21X1 port map( A0 => LSB_CNT_2_port, A1 => LSB_CNT_1_port, B0 => N186, Y => n75); U192 : OAI21XL port map( A0 => n1820, A1 => n19, B0 => n75, Y => N184); U193 : OR2X2 port map( A => n200, B => CNT_5_port, Y => n201); U194 : NAND2BX1 port map( AN => CNT_1_port, B => n176, Y => n197); U195 : NOR2X1 port map( A => n65, B => dn, Y => n66); U196 : OAI21XL port map( A0 => n19, A1 => n183, B0 => n76, Y => N182); U197 : OR2X2 port map( A => n197, B => CNT_2_port, Y => n198); U198 : OR2X2 port map( A => n198, B => CNT_3_port, Y => n199); U199 : OR2X2 port map( A => n199, B => CNT_4_port, Y => n200); U201 : OR4X2 port map( A => CNT_1_port, B => CNT_0_port, C => CNT_3_port, D => CNT_2_port, Y => n203); U202 : OR4X2 port map( A => CNT_5_port, B => CNT_4_port, C => CNT_7_port, D => CNT_6_port, Y => n204); U203 : XOR2X1 port map( A => CNT_7_port, B => n202, Y => N57); U204 : NOR2X1 port map( A => CNT_6_port, B => n201, Y => n202); U205 : INVX1 port map( A => n61, Y => n174); U206 : AOI222X1 port map( A0 => N55, A1 => n540, B0 => CNT_5_port, B1 => n510, C0 => N46, C1 => n530, Y => n61); U207 : OAI2BB1X1 port map( A0N => n200, A1N => CNT_5_port, B0 => n201, Y => N55); U208 : INVX1 port map( A => n62, Y => n173); U209 : AOI222X1 port map( A0 => N56, A1 => n540, B0 => CNT_6_port, B1 => n510, C0 => N47, C1 => n530, Y => n62); U210 : XNOR2X1 port map( A => CNT_6_port, B => n201, Y => N56); U211 : NAND2X1 port map( A => n59, B => n60, Y => n80); U212 : AOI22X1 port map( A0 => N45, A1 => n530, B0 => N54, B1 => n540, Y => n59); U213 : AOI21X1 port map( A0 => CNT_4_port, A1 => n510, B0 => n520, Y => n60) ; U214 : OAI2BB1X1 port map( A0N => n199, A1N => CNT_4_port, B0 => n200, Y => N54); U215 : NAND2X1 port map( A => n570, B => n58, Y => n79); U216 : AOI22X1 port map( A0 => N44, A1 => n530, B0 => N53, B1 => n540, Y => n570); U217 : AOI21X1 port map( A0 => CNT_3_port, A1 => n510, B0 => n520, Y => n58) ; U218 : OAI2BB1X1 port map( A0N => n198, A1N => CNT_3_port, B0 => n199, Y => N53); U219 : NAND2X1 port map( A => n550, B => n560, Y => n78); U220 : AOI22X1 port map( A0 => N43, A1 => n530, B0 => N52, B1 => n540, Y => n550); U221 : AOI21X1 port map( A0 => CNT_2_port, A1 => n510, B0 => n520, Y => n560 ); U222 : OAI2BB1X1 port map( A0N => n197, A1N => CNT_2_port, B0 => n198, Y => N52); U223 : NAND2X1 port map( A => n49, B => n50, Y => n77); U224 : AOI22X1 port map( A0 => N42, A1 => n530, B0 => N51, B1 => n540, Y => n49); U225 : AOI21X1 port map( A0 => CNT_1_port, A1 => n510, B0 => n520, Y => n50) ; U226 : OAI2BB1X1 port map( A0N => CNT_0_port, A1N => CNT_1_port, B0 => n197, Y => N51); U227 : NAND2X1 port map( A => n63, B => n64, Y => n81); U228 : AOI21X1 port map( A0 => CNT_7_port, A1 => n510, B0 => n520, Y => n64) ; U229 : AOI22X1 port map( A0 => N48, A1 => n530, B0 => N57, B1 => n540, Y => n63); U230 : XOR2X1 port map( A => add_75xcarry_7_port, B => CNT_7_port, Y => N48) ; U231 : NAND2BX1 port map( AN => rst, B => n205, Y => n65); U232 : OAI21XL port map( A0 => CNT_6_port, A1 => CNT_5_port, B0 => CNT_7_port, Y => n205); U233 : OAI31X1 port map( A0 => n183, A1 => n1800, A2 => n19, B0 => n72, Y => N190); U234 : NOR2X1 port map( A => n196, B => MSB_CNT_3_port, Y => n69); U235 : NOR2X1 port map( A => MSB_CNT_3_port, B => MSB_CNT_0_port, Y => n70); U236 : AOI21X1 port map( A0 => N187, A1 => LSB_CNT_1_port, B0 => N190, Y => n74); U237 : AOI22X1 port map( A0 => n71, A1 => MSB_CNT_3_port, B0 => n193, B1 => n70, Y => N266); U238 : NAND2X1 port map( A => N187, B => LSB_CNT_2_port, Y => n72); U239 : OAI211X1 port map( A0 => dn, A1 => n67, B0 => n83, C0 => n68, Y => n82); U240 : AOI22X1 port map( A0 => CNT_0_port, A1 => n175, B0 => n176, B1 => up, Y => n67); U241 : AOI21X1 port map( A0 => n176, A1 => dn, B0 => n65, Y => n68); U242 : NAND3X1 port map( A => n69, B => n195, C => MSB_CNT_2_port, Y => N271 ); U243 : NAND3X1 port map( A => MSB_CNT_1_port, B => n69, C => MSB_CNT_2_port, Y => N273); U244 : NAND3X1 port map( A => n69, B => n1940, C => MSB_CNT_1_port, Y => N269); U245 : NAND3X1 port map( A => n193, B => n196, C => MSB_CNT_3_port, Y => N274); U246 : NAND3X1 port map( A => MSB_CNT_0_port, B => n193, C => MSB_CNT_3_port , Y => N275); U247 : NAND3X1 port map( A => MSB_CNT_1_port, B => n1940, C => n70, Y => N268); U248 : NAND3X1 port map( A => MSB_CNT_2_port, B => n195, C => n70, Y => N270 ); U249 : NAND3X1 port map( A => MSB_CNT_2_port, B => MSB_CNT_1_port, C => n70, Y => N272); U250 : NOR3X1 port map( A => n183, B => n72, C => n19, Y => N194); U251 : NAND4X1 port map( A => n19, B => n183, C => n1820, D => n1800, Y => N180); U252 : OAI21XL port map( A0 => n1800, A1 => n19, B0 => n74, Y => N188); U253 : OAI21XL port map( A0 => n72, A1 => n19, B0 => n73, Y => N192); U254 : NAND2X1 port map( A => LSB_CNT_1_port, B => n1810, Y => n73); U260 : INVX1 port map( A => up, Y => n175); LSB_CNT_reg_3 : DFFXL port map( D => CNT_3_port, CK => clk, Q => N187, QN => n1800); LSB_CNT_reg_2 : DFFXL port map( D => CNT_2_port, CK => clk, Q => LSB_CNT_2_port, QN => n1820); MSB_CNT_reg_0 : DFFXL port map( D => CNT_4_port, CK => clk, Q => MSB_CNT_0_port, QN => n196); MSB_CNT_reg_1 : DFFXL port map( D => CNT_5_port, CK => clk, Q => MSB_CNT_1_port, QN => n195); MSB_CNT_reg_3 : DFFXL port map( D => CNT_7_port, CK => clk, Q => MSB_CNT_3_port, QN => n311); MSB_CNT_reg_2 : DFFXL port map( D => CNT_6_port, CK => clk, Q => MSB_CNT_2_port, QN => n1940); Alpha_b_reg_13 : DFFXL port map( D => n34, CK => clk, Q => n310, QN => n129) ; Alpha_b_reg_11 : DFFXL port map( D => n36, CK => clk, Q => n309, QN => n127) ; Alpha_b_reg_14 : DFFXL port map( D => n33, CK => clk, Q => n308, QN => n99); Alpha_b_reg_12 : DFFXL port map( D => n35, CK => clk, Q => n307, QN => n105) ; Alpha_b_reg_10 : DFFXL port map( D => n37, CK => clk, Q => n306, QN => n103) ; Alpha_b_reg_9 : DFFXL port map( D => n38, CK => clk, Q => n305, QN => n109); Alpha_b_reg_8 : DFFXL port map( D => n39, CK => clk, Q => n304, QN => n107); Alpha_b_reg_7 : DFFXL port map( D => n40, CK => clk, Q => n303, QN => n113); Alpha_b_reg_6 : DFFXL port map( D => n41, CK => clk, Q => n302, QN => n111); Alpha_b_reg_5 : DFFXL port map( D => n420, CK => clk, Q => n301, QN => n117) ; Alpha_b_reg_4 : DFFXL port map( D => n430, CK => clk, Q => n300, QN => n115) ; Alpha_b_reg_3 : DFFXL port map( D => n440, CK => clk, Q => n299, QN => n121) ; Alpha_b_reg_2 : DFFXL port map( D => n450, CK => clk, Q => n298, QN => n119) ; Alpha_b_reg_1 : DFFXL port map( D => n460, CK => clk, Q => n297, QN => n125) ; Alpha_b_reg_0 : DFFXL port map( D => n470, CK => clk, Q => n296, QN => n123) ; PhaseMUX_b_reg_6 : DFFXL port map( D => N272, CK => clk, Q => n295, QN => n133); PhaseMUX_b_reg_4 : DFFXL port map( D => N270, CK => clk, Q => n294, QN => n131); PhaseMUX_b_reg_2 : DFFXL port map( D => N268, CK => clk, Q => n293, QN => n137); PhaseMUX_reg_6 : DFFXL port map( D => n1870, CK => clk, Q => n292, QN => n135); PhaseMUX_reg_4 : DFFXL port map( D => n1860, CK => clk, Q => n291, QN => n141); PhaseMUX_reg_2 : DFFXL port map( D => n185, CK => clk, Q => n290, QN => n139 ); PhaseMUX_reg_7 : DFFXL port map( D => n1900, CK => clk, Q => n289, QN => n145); PhaseMUX_reg_5 : DFFXL port map( D => n189, CK => clk, Q => n288, QN => n143 ); PhaseMUX_reg_3 : DFFXL port map( D => n1880, CK => clk, Q => n287, QN => n149); PhaseMUX_b_reg_7 : DFFXL port map( D => N273, CK => clk, Q => n286, QN => n147); PhaseMUX_b_reg_5 : DFFXL port map( D => N271, CK => clk, Q => n285, QN => n153); PhaseMUX_b_reg_3 : DFFXL port map( D => N269, CK => clk, Q => n284, QN => n151); PhaseMUX_b_reg_1 : DFFXL port map( D => N267, CK => clk, Q => n283, QN => n157); PhaseMUX_b_reg_9 : DFFXL port map( D => N275, CK => clk, Q => n282, QN => n155); PhaseMUX_b_reg_8 : DFFXL port map( D => N274, CK => clk, Q => n281, QN => n161); CNT_reg_0 : DFFXL port map( D => n82, CK => clk, Q => CNT_0_port, QN => n176 ); PhaseMUX_b_reg_0 : DFFXL port map( D => N266, CK => clk, Q => n280, QN => n159); PhaseMUX_reg_8 : DFFXL port map( D => n191, CK => clk, Q => n279, QN => n165 ); PhaseMUX_reg_1 : DFFXL port map( D => n169, CK => clk, Q => n278, QN => n101 ); PhaseMUX_reg_9 : DFFXL port map( D => n1920, CK => clk, Q => n277, QN => n163); PhaseMUX_reg_0 : DFFXL port map( D => n1840, CK => clk, Q => n276, QN => n167); CNT_reg_4 : DFFXL port map( D => n80, CK => clk, Q => CNT_4_port, QN => n275_port); CNT_reg_3 : DFFXL port map( D => n79, CK => clk, Q => CNT_3_port, QN => n274_port); CNT_reg_2 : DFFXL port map( D => n78, CK => clk, Q => CNT_2_port, QN => n273_port); CNT_reg_1 : DFFXL port map( D => n77, CK => clk, Q => CNT_1_port, QN => n272_port); CNT_reg_7 : DFFXL port map( D => n81, CK => clk, Q => CNT_7_port, QN => n271_port); Alpha_buffer_reg_0 : DFFXL port map( D => N180, CK => clk, Q => n326, QN => n470); Alpha_buffer_reg_7 : DFFXL port map( D => N187, CK => clk, Q => n319, QN => n40); Alpha_buffer_reg_14 : DFFXL port map( D => N194, CK => clk, Q => n312, QN => n33); Alpha_buffer_reg_6 : DFFXL port map( D => N186, CK => clk, Q => n320, QN => n41); Alpha_buffer_reg_10 : DFFXL port map( D => N190, CK => clk, Q => n316, QN => n37); Alpha_buffer_reg_9 : DFFXL port map( D => n177, CK => clk, Q => n317, QN => n38); Alpha_buffer_reg_12 : DFFXL port map( D => N192, CK => clk, Q => n314, QN => n35); Alpha_buffer_reg_8 : DFFXL port map( D => N188, CK => clk, Q => n318, QN => n39); Alpha_buffer_reg_5 : DFFXL port map( D => n178, CK => clk, Q => n321, QN => n420); Alpha_buffer_reg_3 : DFFXL port map( D => n179, CK => clk, Q => n323, QN => n440); Alpha_buffer_reg_4 : DFFXL port map( D => N184, CK => clk, Q => n322, QN => n430); Alpha_buffer_reg_2 : DFFXL port map( D => N182, CK => clk, Q => n324, QN => n450); Alpha_buffer_reg_1 : DFFXL port map( D => N181, CK => clk, Q => n325, QN => n460); Alpha_buffer_reg_13 : DFFTRXL port map( D => LSB_CNT_1_port, RN => n1810, CK => clk, Q => n313, QN => n34); Alpha_buffer_reg_11 : DFFTRXL port map( D => N187, RN => LSB_CNT_2_port, CK => clk, Q => n315, QN => n36); U83 : CLKINVX20 port map( A => n36, Y => Alpha(11)); U84 : CLKINVX20 port map( A => n34, Y => Alpha(13)); U85 : CLKINVX20 port map( A => n460, Y => Alpha(1)); U86 : CLKINVX20 port map( A => n450, Y => Alpha(2)); U87 : CLKINVX20 port map( A => n430, Y => Alpha(4)); U88 : CLKINVX20 port map( A => n440, Y => Alpha(3)); U89 : CLKINVX20 port map( A => n420, Y => Alpha(5)); U90 : CLKINVX20 port map( A => n39, Y => Alpha(8)); U91 : CLKINVX20 port map( A => n35, Y => Alpha(12)); U92 : CLKINVX20 port map( A => n38, Y => Alpha(9)); U93 : CLKINVX20 port map( A => n37, Y => Alpha(10)); U94 : CLKINVX20 port map( A => n41, Y => Alpha(6)); U95 : CLKINVX20 port map( A => n33, Y => Alpha(14)); U96 : CLKINVX20 port map( A => n40, Y => Alpha(7)); U97 : CLKINVX20 port map( A => n470, Y => Alpha(0)); end SYN_LIA_FSM_arch;
Here is my synthesized code (gate level code):
show me the command you are using to simulate this. the full command, exactly as used.
sh rm -Rf Work
sh mkdir Work
define_design_lib Work -path "./Work"
analyze -format vhdl -lib WORK ../HDLs/LIA_FSM.vhd
elaborate LIA_FSM -arch "LIA_FSM_arch" -lib DEFAULT -update
set_load 5 "PhaseMUX_9_"
set_load 5 "PhaseMUX_8_"
set_load 5 "PhaseMUX_7_"
set_load 5 "PhaseMUX_6_"
set_load 5 "PhaseMUX_5_"
set_load 5 "PhaseMUX_4_"
set_load 5 "PhaseMUX_3_"
set_load 5 "PhaseMUX_2_"
set_load 5 "PhaseMUX_1_"
set_load 5 "PhaseMUX_0_"
set_load 5 "PhaseMUX_b_9_"
set_load 5 "PhaseMUX_b_8_"
set_load 5 "PhaseMUX_b_7_"
set_load 5 "PhaseMUX_b_6_"
set_load 5 "PhaseMUX_b_5_"
set_load 5 "PhaseMUX_b_4_"
set_load 5 "PhaseMUX_b_3_"
set_load 5 "PhaseMUX_b_2_"
set_load 5 "PhaseMUX_b_1_"
set_load 5 "PhaseMUX_b_0_"
set_load 5 "Alpha_14_"
set_load 5 "Alpha_13_"
set_load 5 "Alpha_12_"
set_load 5 "Alpha_11_"
set_load 5 "Alpha_10_"
set_load 5 "Alpha_9_"
set_load 5 "Alpha_8_"
set_load 5 "Alpha_7_"
set_load 5 "Alpha_6_"
set_load 5 "Alpha_5_"
set_load 5 "Alpha_4_"
set_load 5 "Alpha_3_"
set_load 5 "Alpha_2_"
set_load 5 "Alpha_1_"
set_load 5 "Alpha_0_"
set_load 5 "Alpha_b_14_"
set_load 5 "Alpha_b_13_"
set_load 5 "Alpha_b_12_"
set_load 5 "Alpha_b_11_"
set_load 5 "Alpha_b_10_"
set_load 5 "Alpha_b_9_"
set_load 5 "Alpha_b_8_"
set_load 5 "Alpha_b_7_"
set_load 5 "Alpha_b_6_"
set_load 5 "Alpha_b_5_"
set_load 5 "Alpha_b_4_"
set_load 5 "Alpha_b_3_"
set_load 5 "Alpha_b_2_"
set_load 5 "Alpha_b_1_"
set_load 5 "Alpha_b_0_"
#create_clock -name "clk" -period 10 -waveform { "0" "5" } { "clk" }
create_clock -name sysclock -period 10 -waveform {0 5} [get_ports clk]
set_dont_touch_network [get_ports {clk}]
set_clock_latency -source -late -rise 0.800 [get_clocks sysclock]
set_clock_latency -source -late -fall 0.750 [get_clocks sysclock]
set_clock_latency -source -early -rise 0.500 [get_clocks sysclock]
set_clock_latency -source -early -fall 0.460 [get_clocks sysclock]
set_clock_uncertainty -setup 0.1 [get_clocks sysclock]
set_clock_uncertainty -hold 0.1 [get_clocks sysclock]
#derive_clock_uncertainty
#update_timing_netlist
#set_clock_skew -propagated clk
#set_clock_skew -plus_uncertainty 0.1 "clk"
#set_clock_skew -minus_uncertainty 0.1 "clk"
set_fix_multiple_port_nets -all
write -format ddc -hierarchy -output "LIA_FSM_constrained.ddc"
remove_design -designs
read_ddc LIA_FSM_constrained.ddc
#current_design "LIA_FSM_constrained.ddc"
compile -ungroup_all
write -format ddc -hierarchy -output "LIA_FSM_compile1.ddc"
report_area
report_constraints
report_timing -path full -delay max -max_paths 1 -nworst 1
check_design
read_ddc LIA_FSM_compile1.ddc
#current_design "LIA_FSM_compile1.ddc"
compile -map_effort high -incremental_mapping
write -format ddc -hierarchy -output "LIA_FSM_compile2.ddc"
report_area
report_constraints
check_design
#vhdlout_dont_create_dummy_nets = "TRUE"
change_names -hier -rule vhdl
write -f vhdl -hierarchy -output "LIA_FSM_gate.vhd"
change_names -hier -rule verilog
write -f verilog -hierarchy -output "LIA_FSM_gate.v"
#!/bin/ksh -f
ncvhdl LIA_FSM_gate.v
ncvhdl ../testbench/LIA_FSM_TB.vhd
ncelab -TIMESCALE 10ps/1ps -access +r worklib.LIA_FSM_TB:LIA_FSM_TB_arch
ncsim -gui worklib.LIA_FSM_TB:LIA_FSM_TB_arch
#run 1800000ns
#exit
most likely you are not including a verilog file that describes the gates.
this. you forgot the library verilog file.
Synopsis produces both Verilog and VHDL. I am not sure the Verilog file is necessary to sue! only the VHDL file is ok. However, I try to runt he simulation with verilog, but I got the same error.
