[Moved]can somebody help me, how to design ce amplifier thnx
michael 1978
Full Member level 1
can somebody help me, haw to design ce amplifier
calculation, thnx
What config are you using what is the op voltage you are expecting
What is the gain needed and what power is expected
a voltage have to be in midden, for example 12 v , vce=6v , maximum saturation rond 10ampere, and also current rond midden class a amplifier thnx
Please I dont ge tyou exactly. do you want to design op-amp??
Be more clear here I am not able to understand your statement
It is better that the thread starter shows up here then only we can help him furthur
i dont know how to explain good because my english is not so good, to explain in similary way
a simple how to design one ce amplifier,
simplifying my question
What level of gain is your need just tell that we can create one for you
you have to specify the following specification
1. your resistive load value
2. load current ( which is depend on the output voltage divided by the load resistive )
3. your total gain after connecting the resistor ( this will help to find the Ro of the amplifier and the gain before connecting it )
please give us these values
With out knowing any of your need this is a model of CE amp we can give
ok lets take for example voltage gain of 100Milivolt
i am trying to learn electronics self, i am reading the books electronics principles by alberto malvino, can you make one amplifier now in similary way PLEASE
THNX
