[moved] Can anyone please explain how we obtained equation from multiple equations
n.emimal
Newbie level 3
Newbie level 3
Can anyone please explain how we obtained equation (7.8) from (7.6)? in the attached
I do not understand which step is complicated. exp(ix)=cos(x)+ isin(x) // i is same as j
Same way, exp(2*pi*i*n)=cos(2*pi*n)+i*sin(2*pi*n) // if n is an integer, first term is 1 and the second term is zero
Now sum{n=0 to N-1} exp (2*pi*i*(n/N)*alpha) // sum the cos and sin terms separately
// 1+cos(2*pi*alpha/N)+cos(2*pi*2*alpha/N)+cos(2*pi*3*alpha/N) + ... // also add the sine terms
If alpha is multiple of N, then each term becomes 1 and we get N; sine terms all disappear
If alpha is not a multiple of N, we get N cos terms that will add to zero (clear??)
// same with sine
You should know
\[\displaystyle\sum_{n=0}^{N-1}{z^n}=\frac{1-z^N}{1-z} \; \text{if} \; z\ne 1\]
Then if \[z=e^{j \frac{2\pi}{N}(k-r)}\;\;\longrightarrow\;\;z^N=e^{j {2\pi}(k-r)}=1\]
because k,r are integers
Then
\[\displaystyle\sum_{n=0}^{N-1}{e^{j \frac{2\pi}{N}(k-r)n}}=\frac{1-1}{1-e^{j \frac{2\pi}{N}(k-r)}} = 0 \; \text{if} \; k \ne{r}\]
\[\; \text{if} \; k=r \;\;\longrightarrow\;\; \displaystyle\sum_{n=0}^{N-1}{e^{j \frac{2\pi}{N}(k-r)n}}=\displaystyle\sum_{n=0}^{N-1}{1}=N\]
At (7.6), all terms of the summation of k are multiplied by 0 except the term when k=r (by 1)
Thank you very much for your reply. I got this concept, however in the last step how do we get X(r) rather X(r+mN)
Thank you so much. what if the case k=r+mN and what will be the final answer?
k=r+mN is for the (7.7) identity.
in this demonstration 0<= k <= N-1 and 0<= r <= N-1 ==> m=0
