Analog_Domain
Newbie level 6
Hi I need to tabulate some results using cadence calculator. I have given here a expression for a test case for easy understanding, but in general im using diff exp. Suppose ymax(v("/a<31:0>" ?result "tran")) will results all max of a<31:0> and ymax(v("/b<31:0>" ?result "tran")) will results all max of b<31:0> seperately. Is there any method to merge the both so that i need to get both a<31:0> and b<31:0> in the same tabulate.
