[MOVED] analog input from sensor
Bhuvanesh123
Full Member level 1
Singrauli, India, India
i have pir sensor it gives some output voltage with respect to sottunding
if i activate my internal pull down resistor of my analog input pin i am getting correct digital values
if i activate my internal pull up resistor of my analog input pin i am getting no values values(digital value as 0)
Re: analog input from sensor
Usually neither pull-up nor pull-down would be activated for pins configured as analog input. At first sight, you may have misunderstood the configuration options.
By the way, which processor are you talking about?
