[Moved] Advantage of modeling with AMS
gary36
Full Member level 5
Full Member level 5
Would like to know the difference between modeling with Verilog-AMS vs simulink. Which one to chose
Dear Gary,
I would say that regarding modeling, they only differ in simulation speed. Being simulink the fastest.
Meaning that if you want to check functionality of your mixed-signal system at the architectural level, simulink is fine. Although using verilog-ams to model your system in a tool such as Cadence virtuoso, can be quite flexible since you can easily replace the ideal blocks with the designed ones.
But you can go either way.
Regards
